Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 20-01-2007, 01:49
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
printf & User_Autonomous_Code
printf()s that take place in user_autonomous_code are not showing up on my terminal emulator. I'm using the dipswitches to force it into autonomous mode.
The code compiles fine with no errors or warnings, and I'm including <stdio.h>
What am I missing?
Unread 20-01-2007, 02:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: printf & User_Autonomous_Code
Posting your code will help us help you. As it is, we have no idea where your printfs are in your code. If you're calling the printfs in the fast loop instead of the slow loop, then the serial port is getting swamped and isn't having a chance to output the strings.
Unread 20-01-2007, 02:38
FRC #0675
Ah, sorry, I guess I wasn't clear enough.
I'm calling printf('hello world'); from user_routines_fast.c/User_Autonomous_Code in the 'slow' (26.2ms loop area) loop.
Unread 20-01-2007, 02:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
You need to use double quotes.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2007, 02:44
FRC #0675
Ah, my mistake, I am using double quotes. Astronouth just informed me that I need to include the newline or else it won't flush. I'll give that a shot tomorrow.
Printf BillyJ Programming 9 21-01-2006 14:03
pic: The Bobcats 2001 &amp; 2003 &amp; Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
printf isn't printf-ing. Help! Meandmyself Programming 14 15-02-2004 16:27
User_Autonomous_Code() questions sscanf Programming 8 07-02-2004 07:16
