Go to Post Saying that something cannot be done, is always good inspiration for someone to find a way to do it. - Josh Hambright [more]
Unread 20-01-2007, 07:37
AdamHeard's Avatar
Lead Mentor
pic: Team 294 Teaser; The yellow submarine.
Unread 20-01-2007, 07:49
Travis Hoffman Travis Hoffman is online now
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: pic: Team 294 Teaser; The yellow submarine.
Well there's a pot attached to it, so it seems you're going to have closed loop control of whatever system this powers. Are those F-P motors? It reminds me a bit of our dual Fisher-Price/Bosch planetary gearbox combo that powered the first stage of our extension arm in 2004. We did the "gear down for torque, then gear up for speed" thing in a similar configuration to your setup. The output sprocket of the gearbox was attached to a long run of #25 chain that drove the lift, which could quickly lift us with more oomph in reserve. If those are F-P's in the picture, I will guess this is part of your robot lifting system. If they aren't F-P's, I will guess this is the base of an extending arm. Either way, thanks for the memories!
Unread 20-01-2007, 10:04
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
It looks like a Mabuchi motor on the left and a FP on the right. Interesting...
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 20-01-2007, 10:47
Seeing the slot on the right and the hole on the left reminds me of 254's robot from 2 years ago. They used a very similar mechanism for tightening their chain for their arm. I would guess that this gearbox drives half of a double jointed arm (probably the "sholder" joint), and the slot is for tightening the chain.
Unread 20-01-2007, 12:13
run the trap!!!
Team Role: Human Player
And you know what that means! They will be using two of these. I'm betting they will be in the drivetrain.
-Philip J. Fry
Unread 20-01-2007, 12:20
WhiteAres's Avatar
WhiteAres WhiteAres is offline
FRC #1391
Team Role: Tactician
WhiteAres is an unknown quantity at this point
Send a message via AIM to WhiteAres Send a message via MSN to WhiteAres
has anyone seen my beatles collection? i left it somewhere 'round here...
Unread 20-01-2007, 16:56
CraigHickman
Posts: n/a
I'm noticing a lack of standoffs, so I'm guessing this thing will be put onto a frame member. By the size, I'm guessing onto a 1x1 or two. Most likely, from the tourque that thing will put out, it's some sort of arm actuator.
Looks nice!
Unread 20-01-2007, 20:24
AdamHeard's Avatar
Lead Mentor
Okay, a few of you are pretty close. Let's just say we had some "inspiration" from a previous 294 robot or two that may have had some "inspiration" from a previous robot or two.
Unread 29-01-2007, 02:51
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
That is clearly the 254/60/22 arm gearbox mount/tensioner setup from 04 and 05. No question about it. Your newest frame picture only comfirms it. I am sure it'll work out good for you. It worked great for them both years. Very versatile design for sure.
The question is, what improvements did you make/deem neccesary for this years game?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 29-01-2007, 14:59
AdamHeard's Avatar
Lead Mentor
You'll get to see at La, SD and championships...
You guys are scaring me this year though.... You're at SD and LA, 254 is at LA as well...
I wonder if you'll help them win silicon valley for the 10th or so time as well...
I bet you'll be a pretty powerful team this year.
pic: Team 294 proudly presents The Predator Daniel Brim Extra Discussion 2 22-02-2005 02:43
pic: 294 teaser sojouner06 Robot Showcase 16 12-02-2005 22:25
pic: 294: Chairman's Award Teaser CD47-Bot Extra Discussion 18 27-02-2004 20:37
Image Discuss: 294 teaser CD47-Bot Extra Discussion 4 01-02-2003 21:33
Image Discuss: 294 Teaser CD47-Bot Extra Discussion 1 26-01-2003 23:56
