Go to Post my original intention were that the 5 of them were the power rangers, but then i thought of Copioli as the Pink Ranger and laughed... a lot - Mike Schroeder [more]
Unread 20-01-2007, 11:36
Electrical Engineer
Rookie Year: 1995
Re: where to order gear tooth board
Originally Posted by Bruce Meyer View Post
I'm looking for the source of the KOP Allegro ATS642LSH board. I didn't see a supplier in any FIRST docs (Sensor Manual, Guidelines&Practices, etc.) and Digikey just lists the acutal gear tooth sensor, not the evaluation board it's so nicely mounted on in the KOP. Any help/suggestions appreciated, thanks!
Bruce,
The GTS board was custom made for FIRST. It was late in arriving (distributed the day before kickoff) and is not on any web site yet.
I would recommend that you call IFI (903.453.0802) and ask about it. If they don't have it they should be able to point you in the right direction.
Alternatively, each team received 2 boards and quite a few teams will not use them. I'm sure that you could trade with another team to get more.
Regards,
Mike
Mike Betts
As easy as 355/113...
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
