Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 20-01-2007, 12:08
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
pic: 612 New Drive System
Unread 20-01-2007, 12:09
run the trap!!!
Team Role: Human Player
Re: pic: 612 New Drive System
WOW Did you include every bolt in that assembly!?
-Philip J. Fry
Unread 20-01-2007, 14:22
dtengineering's Avatar
AKA: Jason Brett
Nice. You may want to consider a bearing to support the outboard end of the gearbox shafts. There has been discussion of this in other threads, and the advice generally seems to be that if you are not using an outboard support bearing, then make sure you mount the sprocket as close to the gearbox as possible to minimize the cantilevered load on the gearbox shaft. (You can also cut off the unused shaft to save weight, in that case.)
We used a six wheel drive setup last year and loved it... we added omni wheels to one end of the robot, however and found that helped our turning significantly. Not all teams need to do this, but we had very grippy wheels on all corners... even with the centre wheels lowered slightly we still had a problem turning.
Jason
Unread 20-01-2007, 16:06
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They have it designed so their pulleys (they are using a belt drive rather than chain) are very close to their gearboxes. I still recommended not cantilevering the load, but I don't think it will be a very large problem for them.
The best part of the drive-train is the wheels, but I'll let them post the pictures.
Unread 20-01-2007, 23:21
FRC #0612
Team Role: Mascot
Jason,
thanks for your input!
I was wondering what kind of grip you had on your wheels the year you had the turning problem?
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
pic: New Drive System for 703 POLISH703 Extra Discussion 53 19-01-2007 17:33
pic: rookie drive system psycho7 Robot Showcase 13 13-03-2006 10:29
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
pic: SimSwerve Omnidirectional Drive System CD47-Bot Robot Showcase 6 12-06-2004 14:09
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
