Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 20-01-2007, 12:11
Templar1396's Avatar
Templar1396 Templar1396 is offline
student mentor
AKA: Brian Wu
FRC #1396 (Pyrobots)
Templar1396 is an unknown quantity at this point
Send a message via AIM to Templar1396
Bearing problem
Hi, i am from team 1396 and 2 of our bearings keep popping out no matter what we do, is anyone else having this problem?
we get them on the chain and run them for about 15 seconds before they pop out, any help would be very helpful.
Thanks in advace,
Team 1396
Unread 20-01-2007, 12:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bearing problem
Are you talking about the bearings in the wheels?
If so, do you have spacers holding the wheel centered on the axle? if not, you might try making some spacers to fit between the bearings and the chassis, and putting them on the axle on either side of the wheel, so the bearings cannot move sideways.
Unread 20-01-2007, 13:08
student mentor
AKA: Brian Wu
Re: Bearing problem
we are in the middle of trying that, heh we need washers to fit inside the inner sprocket
i really dont like the reason they didn't give us 4 sprockets ;_;
Bearing Flangette Specs Booger Technical Discussion 4 17-07-2006 11:05
Ratchet/slip bearing? Ianworld Technical Discussion 6 20-01-2005 13:04
bearing help jimfortytwo Technical Discussion 9 01-05-2004 06:20
Bushing v. Bearing VinceT Technical Discussion 14 22-12-2003 19:11
Bearing support - Official Mike Martus OCCRA 0 24-09-2002 05:26
