Go to Post Several really good programming and control specialists haunt CD, but a thread titled "motor failure" might not attract their notice soon. - Richard Wallace [more]
Unread 20-01-2007, 13:12
fallen751 fallen751 is offline
FRC #2052
fallen751 is an unknown quantity at this point
hey, stupid question but...
I was wondering if anyone could give me any help. I keep coming up with an error when I try to use this function definition. I haven't declared the function in anywhere else other then this, and it is ahead of any calls to the function so I let it be its own prototype.
int intMax(int x, int y)
{                                //here is where I get the syntax error
	int max = x;
	if(y > max)
   		max = y;
   return max;
would I have to use it as an inline function? any help would be great!
Unread 20-01-2007, 13:15
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: hey, stupid question but...
Hmm, I don't do C much, but have you tried declaring a function prototype at the start of the code?
// Include files
//Prototypes
int intMax(int x, int y);
//main,intMax,etc. below
Also, telling us what error you're receiving might be helpful. Thanks!
Unread 20-01-2007, 13:21
FRC #2052
thanks for the quick response! I just tried prototyping it, but no luck. The exact error i'm getting looks like this
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\Mounds View Schools\My Documents\FrcCode_2007_8722\main.o".
Clean: Deleted file "C:\Documents and Settings\Mounds View Schools\My Documents\FrcCode_2007_8722\user_routines_fast.o".
Clean: Deleted file "C:\Documents and Settings\Mounds View Schools\My Documents\FrcCode_2007_8722\user_SerialDrv.o".
Clean: Deleted file "C:\Documents and Settings\Mounds View Schools\My Documents\FrcCode_2007_8722\ifi_startup.o".
Clean: Deleted file "C:\Documents and Settings\Mounds View Schools\My Documents\FrcCode_2007_8722\ifi_utilities.o".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "main.c" -fo="main.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_SerialDrv.c" -fo="user_SerialDrv.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Documents and Settings\Mounds View Schools\My Documents\FrcCode_2007_8722\user_routines.c:228:Error: syntax error
Halting build on first failure as requested.
BUILD FAILED: Sat Jan 20 12:21:21 2007
Unread 20-01-2007, 13:23
I'm baaaaaaack.
Clean: Done.
Your compiler is telling you that there's an error on line 228 of user_routines.c. Could you post that function and boldface/highlight in some way line 228?
Have you declared any globals x or y already?
Unread 20-01-2007, 13:26
FRC #2052
I don't want to post the entire code (our homebrew mecanum drive code) but at the top of the post where I comment by the bracket is line 228. thanks for your help
Unread 20-01-2007, 13:30
I'm baaaaaaack.
Since I can't see the whole code, and I won't know what functions might already be predefined, have you tried renaming the function to something other than intMax? Try just qwerty or something miscellaneous for now to see if the function might already have been reserved for something.
Unread 20-01-2007, 13:32
Look closely at the lines preceding the one identified as causing the error. I'm guessing you have a missing semicolon or close brace somewhere before your intMax function definition.
Unread 20-01-2007, 13:33
maniac_2040's Avatar
maniac_2040 maniac_2040 is offline
AKA: Matt
FRC #3302 (Turbo Trojans)
maniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these parts
Send a message via MSN to maniac_2040
Check around in your code. It is likely that the syntax error is actually entirely unrelated to that section of the code. Looks like you might have a missing brace or semicolon somewhere.
Unread 20-01-2007, 15:25
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Thank you for calling the Department of Redundancy Agency.
Have you checked for a missing semicolon or closing brace?
http://www.mikesorrenti.com/
Unread 20-01-2007, 15:31
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
This may or may not be way off, but I remember reading somewhere that the C18 compiler has trouble with filenames longer than 64 characters. It wouldn't compile some code that I had in the My Documents folder once, so I put all the code in a folder in the root c: directory. Worked fine after that.
Just something I remember, may or may not help you!
Hope you get it figured out.
Best of luck,
-Chris
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
Unread 20-01-2007, 15:32
Back after 4 years off
FRC #5279
Best of luck,
-Chris
You are right about there being a size limit but that would have given a different error.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 20-01-2007, 15:57
brainonska's Avatar
brainonska brainonska is offline
AKA: Magical Steve
FRC #1155 (Sciborgs)
brainonska is an unknown quantity at this point
Send a message via AIM to brainonska
i could be wrong...
but you declared the integer variable "max" in the function.
try putting "int max;" in your first line of code along with all your other variable declarations and then in the function... "max = ..."
Real programmers don't comment their code:
it was hard to write... it should be hard to understand
Unread 20-01-2007, 17:09
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Originally Posted by brainonska View Post
i could be wrong...
All that would do is make it global, and the error would be different for that. I'm with Mike and the gang, I say it's an error in a previous line, or it doesn't like using int in the function name.
Matt Krass
Unread 20-01-2007, 17:55
tckma's Avatar
tckma tckma is offline
AKA: Tom C.
FRC #2199 (Robo-Lions)
tckma has a spectacular aura abouttckma has a spectacular aura abouttckma has a spectacular aura about
Send a message via ICQ to tckma Send a message via AIM to tckma Send a message via Yahoo to tckma
Are you just trying to build the code or is this error occurring when you download to the RC? If the former, I'd suggest heeding prior suggestions to check for a missing semicolon and/or brace. If the latter, I would check if you may be running out of program memory on the processor. This isn't as much of a problem with 2006 and 2007 RCs as it is with 2005 and earlier RCs, since they increased the code space for 2006. I doubt this is the problem, but my team has run into memory issues in the past.
Tom C.
Software and Controls Mentor
Team 2849
Prior team associations: 1418 ('08-'09), 1100 ('05-'08), 811 ('02, '04-'05), 246 ('03)
Unread 20-01-2007, 21:07
brainonska's Avatar
AKA: Magical Steve
thats true if the variable is only used in a function-level scope
but ive made the mistake of using function-level variable outside the function.
Its probably not the problem, but its worth a try.
Stupid Variable question.... BillyJ Programming 3 20-02-2006 19:49
Stupid question but... Adam Y. Math and Science 6 16-02-2004 19:29
Really stupid question psychoCHIPMUNKK Kit & Additional Hardware 3 15-02-2004 00:26
stupid question x10 Tom Bottiglieri CD Forum Support 1 04-02-2004 22:40
ill probably feel stupid but i do anyway so... Anthony Kesich Programming 8 05-11-2003 12:53
