Go to Post So remember, no matter what the odds, your wildest dreams can come true with science and technology. - Ian Curtis [more]
Unread 20-01-2007, 13:03
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Mystery Sprockets
Before I start, let me preface this by saying that yes, I know there is a previous post on the subject. However, the answers to this post did not lead to a productive answer to the question.
Here's my question: where can our team find more sprockets for the KoP wheels (the normal wheels contained in the kit)? We've looked on and off for the last week. We finally found something we thought would work, but the screw-holes didn't line up.
We know this part number is the one that didn't work out: 35377159. I don't think our team has the capability to machine the steel, so we need something with pre-drilled holes.
One last request: if you know where to find these, just say so; please save the "search before you post" rhetoric for later.
Thanks,
Paul Dennis
Team 1719
Unread 20-01-2007, 13:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mystery Sprockets
Do you really need the steel sprockes, or could you use the aluminum ones from IFI instead? they include spacers, so you can mount them out from the wheel a ways. You may need to tap threads into the holes in the wheels. I haven't tried to put the aluminum sprockets on the new AM plastic wheels, but the bolt pattern seems to be the same (6 each 10-32 on a 1.875" circle), so they should work.
Unread 20-01-2007, 17:27
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
Our mentors have told us that normal operation of the wheels places significant wear and tear on the wheels such that you really should use the steel sprockets. However, if you know this isn't the case, could you elaborate further?
Thanks,
Paul Dennis
Unread 20-01-2007, 18:06
Billfred's Avatar
Billfred Billfred is online now
Thanks,
Paul Dennis
If the robot were running for months straight, then yes, steel would probably be in order.
However, you're running your robot for two minutes at a time, perhaps 50 times tops over the course of a competition season (unless you go to a metric ton of off-seasons). In that sort of situation, I have empirical evidence that suggests that aluminum sprockets, such as those sold by IFI, AndyMark, and perhaps others, wear acceptably. If you're really worried about it, bring a couple of spares (though you should do that as it is)...but you should be fine in most situations with the aluminum sprockets properly installed.
Unread 20-01-2007, 18:25
Gdeaver Gdeaver is offline
FRC #1640
WE used the IFI AL 28 tooth sprockets last year with Custom made spacers on the Skyway wheels. IFI is selling 24 tooth AL sprockets. If used with the Andy Mark KOP wheels, I would recommend some type of reinforcing Spacer.
Unread 20-01-2007, 18:30
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Is there a reason that you cannot drill a new bolt hole pattern in these parts? There are many, many sources for 24-tooth #35 roller chain sprockets. But for almost any application, you may need to do small amounts of post-purchase machining on a part to make it exactly fit the particular requirements of your design. You should be prepared to drill new bolt holes, broach keyways, enlarge the bore, remove the hub, or other minor tasks. You should not be trying to avoid modifying off-the-shelf parts to make them fit your need - you should be enjoying it. It is part of the creative, fun part of creating a new design.
Some have already commented that they are upset they cannot just purchase the exact part they need and bolt it on their robot. What ever happened to the idea that part of the challenge (and part of the fun) of FIRST was creating your own design out of raw materials? If we do nothing but rely on bolt-on solutions, then we are largely relying on the engineering efforts of others, and doing little true engineering of our own. And that, I submit, lessens the experience for all involved.
The real world does not go together like an Erector set. FIRST robots should not either.
-dave
Unread 20-01-2007, 19:24
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
To follow-up on what Dave said, we had to purchase extra gears as well. We couldn't find the EXACT duplicate items either, so had to buy non-broached gears.
We don't have a broach kit, as the full kits cost upwards of $300 dollars. We also do not have an arbor press, another $100 or so. Therefore, we had to call upon some local teams to see who would be willing to help us with the broaching.
After a couple quick emails, I was able to find several teams in the area that were willing to help me with our broaching needs. Turn-around time was 1 day! Try to find that with any other supplier!
So, even though YOU do not have the resources, there are over 1,000 other teams out there that just may. Don't be afraid to ask another team for help. The broaching took an hour of their time, and they were more than willing to actually do the work for me. (I had to fight them off...)
Good luck,
BEN
Unread 20-01-2007, 20:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'll second everything else here. With the short operational time of FIRST robots, we can get away with aluminum and shockingly narrow safety margins all over the place simply because we can always swap a spare and there's not a lot of time for things to go wrong.
Off-topic:
Guys, he just said he doesn't think they have the capability to machine steel. 57 enjoys playing with chop saws, lathes, mills, and rotary dividers as much as the next team, but come on. Telling people "shame, shame" because they don't have machine tools? Is this where we're headed?
Unread 20-01-2007, 23:15
DonRotolo's Avatar
Back to humble
FRC #0832
Perhaps they merely want to focus their efforts on the hard stuff, and buy the easy stuff off the shelf. Time is short, and perhaps they have financial but not human (or machine) resources. He was just asking.
But, I agree with your final point.
Don
Unread 20-01-2007, 23:24
MrForbes's Avatar
AKA: Jim
The wheels use rather large sprockets, with many teeth, and usually the chain wraps more than half way around the sprocket, so the load on each tooth is relatively small. The aluminum sprockets are strong enough for use on wheels, and the smallest size you can commonly get is 24 teeth, I believe.
However, the transmission sprockets are a different story. Some use as few as 9 teeth, so the load per tooth is significantly higher.
The general way of doing things is to use steel sprockets at the drive end of the chain, and aluminum sprockets at the wheel end of the chain. It works.
Unread 21-01-2007, 00:50
dlavery's Avatar
Curmudgeon
Ben, that is exactly on-point. One of the things that every new team learns is that there is always more than one way to skin a cat. Need to add more sprockets to the robot? Get additional parts similar to those in the Kit Of Parts. Can't find exact duplicates? Get one that is close enough, and work with it to allow it to be used. The sprocket doesn't have the right bolt-hole pattern? Borrow a hand drill and drill out a new one. Don't have the right skills to drill the new holes yourself? Talk to your mentors and see if they can help. They don't have the right skills? Talk to nearby teams and see if they can send someone over. They can't make it? Take it over to them and see if they can do it on site..... etc etc etc
There are lots of ways to get things done. It takes some perseverance, creativity, and innovation, but one of the great things about FIRST is that there is a tremendous community out there to help you make it happen if you can't do it all yourself. My fundamental point is that before you have to resort to buying your a way out of a problem, make sure that you really tap all the resources that you have at your disposal. Some of them may not be obvious at first, but they are there and can add to your experience.
-dave
Unread 21-01-2007, 10:03
MrForbes's Avatar
AKA: Jim
One untapped resource could be a "KOP sprockets wanted" post on CD....my guess is many teams are not using them, and there are literally several hundred of those sprockets sitting on shelves and in boxes going unused, right now, as we speak. I personally know of a pair of sprockets, but I don't have authority to give them away.
You migth check the rules first though, as the parts might not be available for sale anywhere, so using "free" ones might not be allowed.
Unread 21-01-2007, 14:30
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
-dave
The first point I would make about this is that you should be able to find more of the types of things that are in the Kit of Parts. There should be a FIRST-related site where you can go and order more of any part that comes with the kit. I know, for example, that IFI Robotics has part of this list (but only with the things they make, obviously). Why are you not able to just go online and order another part? If the answer is that FIRST wants us to practice our drilling skills, then why do the sprockets in the KoP come pre-drilled?
Furthermore, I understand that there's more than one way to get things done. We've already ordered two omni wheels from Andy Mark to see if we can come up with some other solution than 4WD. However, we also wanted to look into the possibility of getting more sprockets. I'm also not sure why you think we should be looking for the most complex solution to a problem (buying pre-drilled or at least easily-drillable parts seems much simpler than drilling new holes in a steel part, which our mentors tell us is much more difficult to machine). We also did ask local teams if they had extras of these parts, and we have not yet gotten any replies.
When we're trying to solve a problem as simple as our drive train, we're going to be looking for a simple solution; getting two more KoP sprockets should be doable. We are examining the alternatives, and one of them should be to get these sprockets. You seem to be critiquing me for not doing exactly what I'm trying to do with my post.
Am I reading this wrong?
Paul Dennis
Unread 21-01-2007, 15:05
Best Available Data
FRC #1778 (Chill Out!)
A regular ol' hand drill will get through steel, but you'll need to be very precise with your measurements.
As far as aluminum sprockets go, let me share a little story. Our rookie year (2004) we purchased these humongous steel sprockets thinking we would need them. We used 1/4 aluminum in our base, and made our goal grabber out of steel. We had a very elegant robot until around 3 days til shipdate when we weighed the thing. 143lbs?!!??!? Oh Noes!!! We lost a lot of our ball holding ability to cut the weight down, as well as drill quite a few not-exactly-in-a-line speed holes. We ended up making weight (which was 130 lbs with the battery).
Fast forward 4 years...
A few nights ago we got a package from AM containing our aluminum #25 sprockets for this years drivetrain. While sitting in our room someone pulled out these giant steel #35 sprockets and we couldn't stop laughing thinking about how we thought that we needed that much strength.
Unread 21-01-2007, 18:14
Onward through the fog.
If I may, I'd like to add a couple of thoughts.
This thread is a healthy thread and I hope a lot of FIRSTers read it.
It is about a specific quest for a specific item, 2 sprockets. Hopefully, at some point, someone will post and say they know how to obtain them.
In the meantime, suggestions, alternatives, ideas, and opinions have been shared. The FIRST community is one that cares deeply about the success of every team and its members. And it cares deeply about the new/newer teams. Sometimes the threads in CD offer unique opportunities to the FIRSTers that post here, interactions with each other that opens the window into the world of FIRST philosophy and applications a little wider. That can be frustrating when one is looking for a specific answer to a specific question and met with alternatives and suggestions encouraging one to be innovative and creative. For now, resolving the sprocket dilemma is important yet, at the same time thinking about and perhaps applying some of the suggestions offered would not be a waste of time or effort. I read this thread and saw it to be a thread of enrichment and helpful support because that is what it is.
~ Helen Keller
(1880-1968)
tachometer mystery? Issues Motors 31 27-11-2005 20:44
pic: 930 Mystery Teaser Gamer930 Robot Showcase 3 14-02-2005 12:03
mystery theater help hollieteam388 Chit-Chat 0 21-01-2004 17:45
Mystery Science Theater 3000 Ryan Dognaux Chit-Chat 3 18-08-2002 16:49
mystery icons Joe Johnson CD Forum Support 2 07-06-2001 22:09
