Go to Post Don’t get caught in mindsets which will limit the potential that the future may hold. - Jaine Perotti [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-20-2007, 02:54 PM
ThatIndianKid89 ThatIndianKid89 is offline
FRC #0611
ThatIndianKid89 is on a distinguished road
Where to buy Ball Bearings?
Do any of you guys know where we can get some open ball bearings like the ones supplied in the kit? The kit has 8, but we need 12.
Shaft Size= 1/2" and the Outer Dia= 1 1/4"
Is there a FIRST "endorsed" site that will supply us with more of these bearings? If not do you know of anywhere where I could get them relatively cheap?
Thanks!
Unread 01-20-2007, 03:23 PM
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Where to buy Ball Bearings?
I don't believe there is a FIRST endorsed site that will sell you more of these bearings. However a wonderful industrial supplier named mcmaster does.
Just head on over to http://www.mcmaster.com and do a search for ball bearings. They'll have what your looking for. The only issue is that they have many, many different options. In general the cheapest bearing will probably be good enough for FIRST robots but I'd also suggest going over the options with a mentor. I've ordered bearings a number of times from them and i'm still not sure what is ideal.
Hope that helps.
Team Website
Unread 01-20-2007, 03:40 PM
FRC #0611
Hope that helps.
Tried it earlier. Unfortunately, they don't carry the right size
Whenever they do have the right size it always is flanged (with that little rim around the bearing).
I need pretty much the EXACT same ones found in the kit (size and shape wise)...
Thanks for trying though!
Unread 01-20-2007, 03:59 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
http://www.andymark.biz/am-0112.html
You can purchase the AM wheel with bearings in it from AndyMark.
If you send AM an email, you probably can purchase the bearings individually if you wanted.
Threaded rod through ball bearings Madison Technical Discussion 38 01-03-2007 01:23 AM
Where to get 1/2" Flanged bearings? sanddrag Technical Discussion 13 01-15-2004 10:04 PM
Drills: The ball bearings are gone? BobbyG Motors 0 01-21-2003 11:57 PM
help! team 497 needs bearings (or info on where to buy) Andrew Dahl General Forum 1 01-21-2003 05:49 PM
where to buy! Ben Mitchell General Forum 2 01-20-2002 11:14 PM
