Curley Tubing
Does any body know where to buy any Legal curley tubing?
Re: Curley Tubing
Here is what we have done in the past that worked fairly well. We take the standard tubing that comes with the kit and wrap it around a PVC pipe then heat it in a oven. I don't recall what temperature or how long, though. You have to experiment with it. Just don't over do it or the tubing will collapse. Another alternative is to use a hairdryer.
Re: Curley Tubing
we do a similar technique except we use a heat gun to do it that works really good for us the heat gun is also good for bending Lexan
Re: Curley Tubing
Buy it... you don't need to build it. Check the Q&A forums which point to rule 106 in the manual... section 8.
http://forums.usfirst.org/showthread...ghlight=tubing As to where to buy it... try calling around to stores that sell air tools. In Vancouver, BC, I know that Princess Auto and KMS Tools would be happy to help you out, but I am sure you can find something local. Jason |
Re: Curley Tubing
The last time that we made it we just struck it into the oven at 350 degrees for about 15 minutes.
Re: Curley Tubing
Read Rule 99. |
| pic: Moe, Larry, and Curley | team222badbrad | Extra Discussion | 7 | 04-03-2006 20:54 |
| Tubing In Autodesk | unapiedra | Inventor | 13 | 24-05-2005 11:59 |
| steel tubing | BBFIRSTCHICK | Rules/Strategy | 2 | 14-01-2003 22:03 |
| Aluminum Tubing | archiver | 2000 | 2 | 23-06-2002 22:35 |
| Tubing | pfortunejr | Technical Discussion | 6 | 11-01-2002 08:10 |
