Re: hey, stupid question but...
i could be wrong...
but you declared the integer variable "max" in the function. try putting "int max;" in your first line of code along with all your other variable declarations and then in the function... "max = ..." |
All that would do is make it global, and the error would be different for that. I'm with Mike and the gang, I say it's an error in a previous line, or it doesn't like using int in the function name.
but ive made the mistake of using function-level variable outside the function. Its probably not the problem, but its worth a try. |
it probably isn't prototyping since it is a syntax error. My guess is that it sometimes tells you there's an error a line or two after the actual error. It may be a problem with the int intmax(int x, int y) line. try changing a couple things to see if that's the problem.
Hey you who had the problem, are you still with us?
Why do you even have 'max'? Couldnt you just use this? Code:
int intMax(int x, int y)
{ //here is where I get the syntax error
if(y > x)
x = y;
return x;
| Stupid Variable question.... | BillyJ | Programming | 3 | 20-02-2006 19:49 |
| Stupid question but... | Adam Y. | Math and Science | 6 | 16-02-2004 19:29 |
| Really stupid question | psychoCHIPMUNKK | Kit & Additional Hardware | 3 | 15-02-2004 00:26 |
| stupid question x10 | Tom Bottiglieri | CD Forum Support | 1 | 04-02-2004 22:40 |
| ill probably feel stupid but i do anyway so... | Anthony Kesich | Programming | 8 | 05-11-2003 12:53 |
