Go to Post Also, the judges don't give out awards for money. They give out awards for hard work and effort. - BigJ [more]
Unread 20-01-2007, 15:29
natis's Avatar
natis natis is offline
natalia
AKA: natalia soberanes
FRC #0987 (High Rollers)
natis has a spectacular aura aboutnatis has a spectacular aura aboutnatis has a spectacular aura about
Send a message via MSN to natis
Curley Tubing
Does any body know where to buy any Legal curley tubing?
Team 987 - The High Rollers - Las Vegas, Nevada
2002 -- Nationals Highest Rookie Seed
2003 -Xerox Creativity Award
2004 -LA Regional Semi-Finalists
2005 - Arizona Regional Finalists -- GM Industrial Design Award -- Las Vegas Regional Champions
2006 - Delphi "Driving Tommorow's Technology" Award -- Radio Shack Innovation in Control Award
2006 - Las Vegas Regional Champions -- Arizona Regional Finalists
2007 -Motorolar Quality Award
2007 - SVR semifinalist -- Las Vegas Regional Finalist
2007 --WORLD CHAMPS!!!
Unread 20-01-2007, 16:18
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Curley Tubing
Here is what we have done in the past that worked fairly well. We take the standard tubing that comes with the kit and wrap it around a PVC pipe then heat it in a oven. I don't recall what temperature or how long, though. You have to experiment with it. Just don't over do it or the tubing will collapse. Another alternative is to use a hairdryer.
Unread 20-01-2007, 16:31
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
Re: Curley Tubing
we do a similar technique except we use a heat gun to do it that works really good for us the heat gun is also good for bending Lexan
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 20-01-2007, 17:48
dtengineering's Avatar
AKA: Jason Brett
Re: Curley Tubing
Buy it... you don't need to build it. Check the Q&A forums which point to rule 106 in the manual... section 8.
http://forums.usfirst.org/showthread...ghlight=tubing
As to where to buy it... try calling around to stores that sell air tools. In Vancouver, BC, I know that Princess Auto and KMS Tools would be happy to help you out, but I am sure you can find something local.
Jason
Unread 20-01-2007, 17:52
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Re: Curley Tubing
The last time that we made it we just struck it into the oven at 350 degrees for about 15 minutes.
Unread 20-01-2007, 18:22
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Curley Tubing
You are creating a potential hazard when you do this. You are changing the strength of the tubing and could cause it to fail. It is rated to be safe at 120 psi out of the box - but who is to say what it is after a heat cycle in an oven or with a heat gun.
Read Rule 99.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
pic: Moe, Larry, and Curley team222badbrad Extra Discussion 7 04-03-2006 20:54
Tubing In Autodesk unapiedra Inventor 13 24-05-2005 11:59
steel tubing BBFIRSTCHICK Rules/Strategy 2 14-01-2003 22:03
Aluminum Tubing archiver 2000 2 23-06-2002 22:35
Tubing pfortunejr Technical Discussion 6 11-01-2002 08:10
