Go to Post When Andy Baker holds an iPhone 4 in his left hand, the signal [i]increases[/i]. - Billfred [more]
Unread 20-01-2007, 17:44
kwilliam's Avatar
kwilliam kwilliam is offline
FRC #1038
kwilliam has a spectacular aura aboutkwilliam has a spectacular aura about
Re: Dashboard .ini file, configuration
The User Bytes and LEDs are set in the Default_Routine in user_routines.c, if I recall correctly. The LED's correspond to those on the Operator Interface.
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Configuration File? FFnut Programming 2 03-02-2006 17:38
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
Dashboard OCX file Ameya Programming 2 31-12-2002 14:50
