Go to Post On the one hand, I wouldn’t want to discourage innovation. But on the other, I would want to encourage simplicity. - Jack Jones [more]
View Poll Results: What is better
Ramp Bot 56 39.72%
Arm Bot 65 46.10%
Something Else 47 33.33%
Multiple Choice Poll. Voters: 141. You may not vote on this poll
  #31   Spotlight this post!
Unread 20-01-2007, 11:01
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Re: Ramp bot vs. Arm bot
I my opinion a ramp bot is only as good as the drivers on the alliance. Trying to drive a robot on another bot with the same footprint is difficult at best. And I know that all teams will build to the fullest dimension possible making the task even more interesting.
The one thing I learned last year is that 30 degrees may not seem like a lot but many bots required a running start to get up and the number that rammed the back wall was staggering. Now imagine the back wall is your arm.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
  #32   Spotlight this post!
Unread 20-01-2007, 11:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That might depend on how clever the ramp design is. 27" wide ramps on top of the robot don't need to be only 27" wide on the floor.
  #33   Spotlight this post!
Unread 20-01-2007, 12:51
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
Good point. Although I don't think that that would happen often. Any team that can adequatly create a robot with a working arm and a ramp then I think that they would be able to find some way to shield it or protect it.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
  #34   Spotlight this post!
Unread 20-01-2007, 13:45
The Revolver's Avatar
The Revolver The Revolver is offline
The Rollercoaster Expert
AKA: Michael Foley
FRC #1741 (Red Alert Robotics)
Team Role: Driver
The Revolver is an unknown quantity at this point
Ramp VS. Arm? How about both, duh...
Check out last years robot: The Revolver
  #35   Spotlight this post!
Unread 20-01-2007, 16:51
cam1031's Avatar
cam1031 cam1031 is offline
FRC #1835
cam1031 is an unknown quantity at this point
The Perfect Alliance
The perfect alliance is 2 score-bots and one lift-bot.
this is because with three score-bots the other team is able to score without anyone trying to prevent them.
with one lift-bot the other team has atleast one bot trying to prevent them from making the points.
  #36   Spotlight this post!
Unread 20-01-2007, 17:29
Back after 4 years off
FRC #5279
Re: The Perfect Alliance
Who says a scoring bot can't play defense, keep in mind ties in your record are decided by the average number of points the losing alliance in each of your matches had, it is in your best intrest to just score more than your oppnents can rather than prevent them from scoring.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
  #37   Spotlight this post!
Unread 20-01-2007, 18:04
SSMike's Avatar
Team Role: Operator
Obviously it would be best if you could make a ramp and arm bot. But it would be hard. Especially because an amatuer driver on your alliance might crash into your arm and damage it. I think that it is better to focus on one attribute and then if there is time, try the other one.
Long Live #4
  #38   Spotlight this post!
Scion13's Avatar
Scion13 Scion13 is offline
AKA: Steve
FRC #1727 (REX)
Scion13 is on a distinguished road
The perfect alliance would be 3 scoring robots, with atleast one with ramps as well.
REX 1727
www.dulaneyrobotics.com
2007 Chesapeake Chairman's Award
2007 Chesapeake Safety Award
2007 New Jersey Entrepreneur Award
2006 Pittsburgh Rookie All-Star Award
2006 Pittsburgh Website Award
2006 Annapolis Best Seeded Rookie Award
Go BAA!
(Baltimore Area Alliance)
  #39   Spotlight this post!
Unread 20-01-2007, 19:31
robochick1319's Avatar
robochick1319 robochick1319 is offline
Robochick1319
AKA: Catherine
FRC #1319 (Flash)
robochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond repute
Originally Posted by Phoenixseeker View Post
Spoiler: How About a robot that will Lift two others more than a foot off the ground and still can score on the rack?
and one that makes weight? not seeing it
17 x UL Industrial Safety Award Winner (2005 - 2015)
2015 Curie Division Industrial Safety Award sponsored by Underwriters Laboratories
2015 Georgia Southern Classic Champion
2010 Palmetto Regional Engineering Inspiration Award Winner
2008 Peachtree Regional Champion
2007 Galileo Division Champion
2007 Palmetto Regional Champion
2006 Boilermaker Regional Champion
  #40   Spotlight this post!
Unread 20-01-2007, 19:35
Nica F.'s Avatar
Nica F. Nica F. is offline
Mechanical Design Engineer
AKA: That silly panda girl from back in the day.
Nica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond repute
the way i see it,
if you go for arm bot, you really need to know how you want to play the game, and come up with the right strategies for it. If played right, it will obviously be a great advantage for your alliance.
as for the ramp bot, it could easily become a decision maker for any match, because if you are in fact able to lift those robots high enough, that's a big chunk of points.
2 cents.
Product Designer, Mechanical Engineer
Purdue Aeronautical and Astronautical Engineer Graduate - Boiler up!
Team 22 Double Deuce / Team 4 Element Alumni / Former 1646 Precision Guessworks Mentor
  #41   Spotlight this post!
Unread 20-01-2007, 20:53
Dianna Bartone
Posts: n/a
Here's what I'm thinking: What if your goal is to build a robot with an arm as its main attribute, but you're team is feeling ambitious and decides that if they can lift two robots 4" off the ground, that would make the robot that much more desirable. So you build the bot and you do reasonably well in the qualifying matches, but you still need to be picked by someone to play in the elimination round. If the top-placing teams are looking for a good ramp bot, wouldn't they want one that can lift the robots 12" up, making the ramps superfluous as a desirable feature?
How likely do you think it is that the top teams will want a 12"-lifting robot on their side?
Do you think that some would value 4 inches and an arm more than the above or do you think that a robot like this will have to rely on simply their arm to get picked on an alliance?
Will the points that a robot with 4" ramps wins off of them in the qualifying matches be enough to make the ramps worthwhile?
Just something else to think about...as if we needed more...
  #42   Spotlight this post!
Unread 20-01-2007, 21:32
SSMike's Avatar
Team Role: Operator
Thanks for replying. That was a really good point. I think if the you have a ramp bot and are not one of the top 8 seeds at the end, then you will probably be picked. This is only because I think that arm bots will make up most of the top 8. If you have 2 or even one arm bots, they are going to be looking for a ramp bot. So if you have one that elevates 2 bots 12 inches off of the ground, then you have a good chance of being picked.
If that ramp bot also has an arm that can score, if not perfectly, but here and there, then they will definitely be picked.
Just my opinion. Good luck at your competitions!
Long Live #4
  #43   Spotlight this post!
Unread 20-01-2007, 22:03
FRC #5279
I know atleast 3 teams doing it, I only know of three because I have only talked to 3 teams.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
  #44   Spotlight this post!
Unread 20-01-2007, 22:05
SSMike's Avatar
Team Role: Operator
Originally Posted by JamesBrown View Post
If your team could use some help especially with the strategy portion of the game PM me, I am over at RPI, I don't have a car but I could get over there a couple of nights to meet with you. I talked to your mentors at the RPI/GE FLL competition
I'll ask the Team it would be cool to meet someone from another team that is in the area
Long Live #4
  #45   Spotlight this post!
Unread 20-01-2007, 23:31
President, VEX Robotics, Inc.
It happens every year ... most people grossly underestimate how hard it will be to score, in any fashion.
This year we have the "we are going to do it all" people. If you can do it all, then great, but I doubt you will "do it all" well. In this game it is not necessary to do it all. Not by a long stretch.
A good team who concentrates on being a two robot lifter will have a better two robot lifter than a good team who tries to do it all.
A good team who concentrates on being a fast ring scorer will be able to score faster than most of the "do it all" scoring robots. History has shown this time after time.
Now there will be the top few percent of teams who will do it all, and do it better than most, but it will not at all be necessary. This game needs great scorers. This game needs great lifters. This game is played by 3 teams playing together and will be won by 3 teams that combine to have great scoring and the ability to lift.
And of course, we will be doing it all
Arm Placement on Bot? Po-ser Technical Discussion 7 13-01-2007 15:19
Dr. Bot JamizzleHavok13 NASA Discussion 0 28-03-2005 14:33
Bot blocks field with arm in LZ - Penalties? Swampdude Rules/Strategy 8 02-03-2005 15:00
S.P.A.M. 05 BOT tiffany34990 Robot Showcase 14 09-02-2005 11:04
Stretcher Bot archiver 2001 10 24-06-2002 02:42
