Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 20-01-2007, 18:17
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Rookie team Question error 7
I am using labview with the cmucam2 app, when I press run I error 7 occurred at open file+.vipen file. I need help to move foward.
Unread 20-01-2007, 19:16
foote stepped in
AKA: E. Foote
FRC #0868
Re: Team 868
We are getting this same problem and do not know where to turn next. Our team did have the camera working once but now we only see the following when LabView application is started. Installed NI Visa but this did not appear to help. Using USB to Serial connection on camera and this is picked up in Visa Interactive Control. Only seeing green light on camera when is is powered on. Did see red once before but not now. Also need assistance!!!!!!!
-1073807246
Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->CMUcam2.vi->CMUcam2 GUI.vi
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 21-01-2007, 11:01
foote stepped in
AKA: E. Foote
FRC #0868
Re: Rookie team Question error 7
We are still having problems and get the following error when camera is powered on and application is started in Labview. Followed all instructions in PDF FRC2006 Labview-based CMUcam2 Demo and see the following error in Labview. Visa is installed and com port is configured correctly. Can any one help.
-1073807339
VISA Read in query for result from serial port.vi->CMUcam2.vi->CMUcam2 GUI.vi
Unread 21-01-2007, 14:58
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
We went through some process using MAX and setup the COM port, then it started working for us. I don't remember what the exact steps were, though. If no one helps you out by tomorrow then I can give you instructions from the team's laptop.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 21-01-2007, 19:50
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
I always knew it was a bad idea to only upload/provide patches to the software instead of a full version every time we updated it. However, ChiefDelphi would only let us upload up to 3MB to the server while the full package was somewhere around 5MB. Oh well.
Please remove the current CMUCam2 LabVIEW application from your computer, and download the package provided in this post:
http://www.chiefdelphi.com/forums/sh...9&postcount=10
This should work without problems.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 21-01-2007, 19:54
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Here's a list of things that could be wrong:
  1. Do you have the correct COM port selected in the CMUCam2 Application?
  2. You're not connecting the camera through the Serial port to the computer AND the TTL port on the robot controller, are you?
  3. Is your backup battery FULLY CHARGED? The camera uses the backup battery for its power, and if the camera isn't getting the absolute full charge then the camera won't communicate.
  4. Make sure all programs that could be using that port are shut down; this includes hyperterminal, IFI loader, etc...
I want you to review this thread and see if you can get ANYTHING out of the camera:
http://www.chiefdelphi.com/forums/sh...83&postcount=9
If you cannot get anything to come out of your camera, and you are dead sure your camera is being powered at the correct voltage, then you may have a bum camera. I'd like for you to debug this a bit more before saying you have a bum camera, however, since bum cameras aren't a common occurrence.
-Danny
Danny Diaz
Unread 21-01-2007, 20:03
mkluless2 mkluless2 is offline
mkluless2 is an unknown quantity at this point
We also have this problem. After error 7, at the bottom, it says NI-488 board not found. What is this? Will try the other steps tomorrow & hope it helps.
Unread 21-01-2007, 23:06
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
The error it's giving you is really just a generic error for the "class" of errors that the error code can represent. Some errors you may run into will have up to 5 or more "possible problems", it's up to you to decide which "problem" the error refers to in order to troubleshoot the error. In this case there are 2 errors, one that says that the file is not found and one that says that the NI-488 board is not found - since you're not working with an NI-488 board (GPIB interface board) it's safe to say you can ignore that possible reason for the error.
-Danny
Danny Diaz
Unread 21-01-2007, 23:08
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
-Danny
so that's what the problem was! thanks for clarifying that, we may get labview working soon!
Rookie question, appoligies in advance s_forbes Technical Discussion 2 13-01-2006 01:30
Rookie Question joeblob General Forum 2 18-12-2004 11:22
rookie question haverfordfords Robotics Education and Curriculum 2 06-12-2004 18:27
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
Rookie question archiver 2001 8 23-06-2002 23:21
