Re: Power Distribution Block Mounting
I have asked the Q&A forum whether we need to use ALL four of the red and ALL four of the black power blocks. I suspect an answer will be posted there shortly. Hopefully we will be able to access the modular nature of the Rockwell system to remove redundant blocks.
Jason P.S. Don't know what you are using to bolt the components down, but we use #8 nylon machine screws... that saves a bit of weight over using steel. Good luck. |
| Question:Power Distribution Block | Pavan Dave | Electrical | 35 | 20-03-2007 20:10 |
| Power Distribution Block Wiring | slimemonkey | Electrical | 11 | 04-02-2007 18:40 |
| Power distribution Block? | Pontchartrain | Electrical | 3 | 27-01-2006 07:30 |
| Stinger Fuse Block and Power Distribution Block | Don Wright | Electrical | 2 | 30-03-2004 10:45 |
| Power Distribution Block | DukesElectrical | General Forum | 0 | 09-02-2004 23:48 |
