Go to Post This 6 weeks of work, sweat, thinking, designing, building, talking, discussing, turning wrenches, wiring, programming, drawing on chalk boards, eating pizza, drinking mountain dew, with the students - is what the FIRST experience is really about. - meaubry [more]
Unread 20-01-2007, 20:23
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Is this possible? (Gears and chains)
http://www.cabaret.co.uk/education/geneva.htm
Good stuff.
Think of your half gear as the Yellow part and your full gear as the blue one.
I would like to see you try that and see if it would actually be effective.
Unread 20-01-2007, 23:06
DonRotolo's Avatar
Back to humble
FRC #0832
In most cases, you need the full hub (the part surrounding the hole in the middle) of the sprocket to mount it to a shaft. You can also make the hole bigger, or drill holes to bolt the sprocket to something.
In any case, you cannot depend upon friction or an adhesive to prevent the sprocket from spinning on the 'shaft' - you must use a roll pin, or set screw, or square/woodruff key, or some other method.
Considering that, you might just use the whole sprocket. As others have stated, if you really can't afford a sprocket, ask here. Many teams have extras lying around, and will happily share with you.
As maltz1881 stated, success will be getting a robot that passes inspection and can move on the field. Everything after that is gravy.
It's not about the robot - search on that phrase to understand what that means.
Don
What is the hardest (yet possible) task in this year's game? Wayne C. General Forum 88 16-01-2008 18:30
Is this possible? WhiteTiger Control System 2 08-02-2005 16:53
power transmission NOT using gears/chains? Frank(Aflak) Technical Discussion 37 21-05-2003 12:50
Possible Edurobot Gears Source Adam Y. Robotics Education and Curriculum 2 13-12-2002 15:27
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
