Re: MPLAB 7.20 Help please?
I do not know how you are managing to do this. From MPLAB select Project>Build Options>Project and click in the MPLINK Linker tab and then verify that INHX32 is selected. My guess is that this is not your problem...
My guess is that you are getting an error which is halting the build process... Any error messages? Mike |
i had this problem when the project we were editing was burried very deep in the directory tree. try closing down MPLAB. copy your entire working directory, then paste it somewhere near the root directory such as:
C:\mcc18\projects\{working folder} then open your workspace again in MPLAB and try build all function. slloyd |
I also had this same problem and as slloyd said, the project was burried very deep. I just created a directory: C:/camera and put the project in there. Then, changed the output directory to that path since it was still creating the .coff file after the directory change.
After you go Project -> Build All -> Project, you go to the MPLINK Linker tab and check "Suppress COD file generation." That worked for me.
wow thanks so much for the help everyone .. you're all so much friendlier and willing to help than id expected ... again many thanks!
![]() good luck to you all! |
Welcome to the world of Gracious Professionalism. Helping each other out is part of the culture we're trying to spread. Soak it up and pass it along. While FRC teams are certainly rivals, we are not enemies.
#7
Absolutely. and ya, here's what i get now when i build... ------------------------------------------------- MPLINK 3.94, Linker Copyright (c) 2005 Microchip Technology Inc. Errors : 0 MP2COD 3.94, COFF to COD File Converter Copyright (c) 2005 Microchip Technology Inc. Errors : 0 MP2HEX 3.94, COFF to HEX File Converter Copyright (c) 2005 Microchip Technology Inc. Errors : 0 Loaded C:\frc_camera_21\camera.cof. BUILD SUCCEEDED: Sun Jan 21 12:17:30 2007 ------------------------------------------------- and its building a hex. so thanks a lot -out of curiousity should it still say .cof? here: Loaded C:\frc_camera_21\camera.cof. BUILD SUCCEEDED: Sun Jan 21 12:17:30 2007 |
#8
glad to help
#9
another problem now.. in the com1 terminal window.. it doesnt display any of my printfs... which is puzzling...
essentially this is all i want to see: ------------------------- rot = Get_Analog_Value(rc_ana_in01); temp = Get_Analog_Value(rc_ana_in02); pot = Get_Analog_Value(rc_ana_in03); ac = Get_Analog_Value(rc_ana_in04); printf("rot: 3%d, temp: 3%d, pot: 3%d, ac: %d/r", rot, temp, pot, ac); |
#10
The carriage return character is \r.
#11
^ omgosh .. bleh what a small and terrible error on my part.. thanks for catching that..
-however, it still does not diplay anything in the com1 terminal window.. maybe this will help: when i unplug the frc controller from the main power (12V) the com terminal window prints: IFI> it does this once for every time i unplug, then plug back in, the power to the controller... hmm?? ------ and it seems like everytime i turn around im getting some new error--- any help? INK 3.94, Linker Copyright (c) 2005 Microchip Technology Inc. Error - section '_entry_scn' type is non-overlay and absolute but occurs in more than one input file. Errors : 1 BUILD FAILED: Sun Jan 21 18:30:34 2007 Last edited by groovy69 : 21-01-2007 at 18:47. |
#12
http://www.chiefdelphi.com/forums/sh...ad.php?t=51256 This thread has information on the '_entry_scn' error.
| Help with MPLAB | burningpig | Programming | 9 | 17-01-2007 13:10 |
| Please help; HUGE mplab problem | brennerator | Programming | 5 | 09-01-2007 01:25 |
| MPLAB IDE HELP | Idaman323 | Programming | 2 | 16-02-2005 18:01 |
| PLEASE HELP US FIND OUR MOMMY (or MPLAB) | superlou | Programming | 3 | 23-02-2004 16:33 |
| pic: please help us please mortals | CD47-Bot | Robot Showcase | 5 | 25-01-2004 11:03 |
