Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 20-01-2007, 17:24
Sykan's Avatar
Sykan Sykan is offline
Lead Programmer
AKA: David
FRC #0540 (Team 540)
Sykan is on a distinguished road
Math.h sin syntax error
Im trying to use the math.h sin function but i keep getting a syntax error. Im trying to use trig to figure out how far away our bot is from the target light. Heres what's not working:
int targheight;
float dist;
targheight = 3;
dist = ((int)targheight * float sin(((3.14159 / 2) - ((((((int)TILT_SERVO - 190) * (65 / 124)) * (3.14159 / 180)))))) / float sin(float((((((int)TILT_SERVO - 190) * (65 / 124)) * (3.14159 / 180)));
Unread 20-01-2007, 17:31
Back after 4 years off
FRC #5279
Re: Math.h sin syntax error
What line is geting the syntax error, and what is the error(if your compiler gives you some knid of error report.)
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 20-01-2007, 17:52
radicalnerd radicalnerd is offline
Registered Luser
FRC #0668 (Apes of Wrath)
radicalnerd is an unknown quantity at this point
Send a message via AIM to radicalnerd
You seem to be missing some closing parentheses for those bolded open parentheses. Try using a text editor that has parentheses highlighting like notepad2. Also it might be easier to read if you split it up over multiple lines (it's not really more efficient code if you write it all on one line.)
dist = ( (int)targheight * float sin(((3.14159 / 2) - ((((((int)TILT_SERVO - 190) * (65 / 124)) * (3.14159 / 180)))))) / float sin ( float ( (((((int)TILT_SERVO - 190) * (65 / 124)) * (3.14159 / 180)));
Unread 20-01-2007, 19:16
Sykan's Avatar
Lead Programmer
AKA: David
The line with the error is:
The error is:
C:\frc_camera_2\frc_camera\user_routines.c:360:Err or: syntax error
Halting build on first failure as requested.
BUILD FAILED: Sat Jan 20 19:11:20 2007
Unread 20-01-2007, 20:52
The parentheses don't match, that's for sure. I'm no expert in C syntax, but the "float sin" part looks wrong too.
I'd create a lookup table in advance and use it instead of doing all that complicated and time-consuming calculation on the fly.
Unread 20-01-2007, 20:55
Electrical Engineer
Rookie Year: 1995
Radicalnerd told you at least part of your problem. You have a different number of open parenthesis than you have close parenthesis. You also seem to be attempting a type cast of float without the required parenthesis.
Mike Betts
As easy as 355/113...
Unread 20-01-2007, 22:28
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
int targheight;
float dist;
targheight = 3;
If you're trying to get the horizontal distance between you and the rack, and you have the angle measure from the camera, and you have the height of the light, wouldn't you use tan to find the distance?
I would suggest dividing those numbers and rounding at whatever number of digits you feel comfortable at. That will eliminate 5 pairs of parentheses. Also, you could do some of that math in earlier steps and use a final, easy to read line for the distance.
Assuming you want the horizontal distance to the rack from your robot, maybe...this (I'm assuming TILT_SERVO is an angle measure):
int targheight;
float dist;
targheight = 3;
dist = targheight / tan(TILT_SERVO);
What place are we at? ... TODAI!
Unread 21-01-2007, 03:04
JohnC's Avatar
This is what I was trying to say:
http://kevin.org/frc/2007_frc_range_calc.pdf
Unread 21-01-2007, 09:26
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
dist = ((int)targheight * float sin(((3.14159 / 2) ...
should be
dist = ((int)targheight * (float) sin(((3.14159 / 2) ...
to recap:
1. make sure parenthesis are properly matched up
2. type casts such as int and float need to be in their own parenthesis
like you did with (int) already
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Array Syntax Error Andrew Blair Programming 7 05-02-2006 14:11
Syntax Error! Denz Programming 15 04-02-2006 23:57
Simple Syntax Error miketwalker Programming 6 06-01-2004 00:17
