Re: Cable/winch vs. chain for telescopic arm
Google "crank up tower" and look at the mechanisms used for antenna towers that use mautiple sections to go from 20 feet to 120. The same basic idea works for robots.
2 years ago we used a simple elevating tower, a 24" stroke 3/4" dia pneumatic piston provided the lifting force, we telescoped 1 x 2 rectangular tubing inside 1.5 x 2.5, using HDPE wafers to keep the inner tube centered. Don |
Okay... after searching CD-Media for "648" I have found a picture of our robot. I had forgotten that I posted it. Um... you can see the nylon pulleys near the bottom. Unfortunately I don't have a closer picture.
648 Little Better Picture |
| Chain Driven Telescoping Arm | BadKarma | Technical Discussion | 8 | 05-06-2005 12:19 |
| Telescopic arm pictures. | sj31419 | Technical Discussion | 3 | 02-02-2005 16:34 |
| Telescopic Arm and grabber design help | M. Hicken | Technical Discussion | 13 | 17-01-2005 12:56 |
| PWM Cable Clip for Victors | sanddrag | Technical Discussion | 9 | 18-07-2004 19:27 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
