Go to Post If there's one thing that I love, it's a good scouting challenge! - wilhitern1 [more]
Unread 20-01-2007, 20:39
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Potentiometer PID
Any 100K Pot will work for most arms a single turn will work. Digikey.com and Mouser.com have parts for 100K 10 turn but you loose some resolution using a 10 turn. I haven't found any 2 turn 100K pots.
Unread 20-01-2007, 22:56
DonRotolo's Avatar
Back to humble
FRC #0832
We had some awful results 2 years ago with 100k pots on the robot. Last year we used 5k pots on the robot and had great success. I attibute the difference to noise and a close match to the input impedance of the ADC circuit.
Am I crazy?
Don
Unread 21-01-2007, 02:41
NextPerception NextPerception is offline
Sleep-Deprived
AKA: Matt
FRC #0437 (Richardson Robotics)
NextPerception has a spectacular aura aboutNextPerception has a spectacular aura aboutNextPerception has a spectacular aura about
Send a message via AIM to NextPerception
instead of
      if ( Button1 == 1 )
            Target = 200 ;
      else if ( Button2 == 1 )
            Target = 400 ;
      else if ( Button3 == 1 )
            Target = 600 ;
i would do this
      if ( (Button1 * Button2) + (Button2 * Button3) + (Button3 * Button1) + ( Button1 + Button2 + Button3 ) == 1 )   //prevents crazy values if more than one button is pressed and keeps the same value if no button is pressed
            Target = (Button1 * 200) + (Button2 * 400) + (Button3 * 600)
this just makes more sense to me and I just post it here for any like minded people out there. I think it takes a little less cpu time too.
What is this S - L - E - E - P you speak of?
Battlebots - My Robotics Website
Unread 21-01-2007, 02:43
Joel J's Avatar
Joel J Joel J is offline
do you..
Am I crazy?
Don
You aren't crazy. Those ADC inputs on the RC are rated for not much more than 2.5K. You should use a 1 or 2K pot when connecting to the RC. For the OI you'll need a 100K pot.
Bourns makes the "good stuff." Avoid radioshack's potentiometers .
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 21-01-2007, 11:03
Originally Posted by NextPerception View Post
i would do this
It makes sense if you're averse to using procedural programming and prefer functional programming. The logic behind your code gives the same result as the one using if statements, but the reason for doing it that way is obscure to anyone encountering it cold.
And it takes a lot more time to do it your way. A few comparisons and branches are faster than many multiplications and additions. Note that the original code never does more than three comparisons and one assignment. Yours always does six multiplications, thirteen additions, and one comparison. It would be instructive to compile both alternatives and compare the generated assembly language code in the listing file.
As an aside, wouldn't it work just as well to simplify the condition to this?
if ( ( Button1 + Button2 + Button3 ) == 1 )
Unread 21-01-2007, 16:59
Sleep-Deprived
AKA: Matt
hahaha
wow. this is what no sleep does to you.
thanks for that.
maybe I just think weird or something
Unread 09-02-2008, 21:37
Chris1228 Chris1228 is offline
FRC #1228
Chris1228 will become famous soon enough
how do u get pot sensors to work on easy c?
Unread 11-02-2008, 13:30
Kingofl337's Avatar
AKA: Adam
The Analog Input block,
The Analog Input function block allows the user to define behavior based on signals from any analog sensor. Analog sensors provide a range of feedback with the range depending on the actual sensor being used. This generic input can be used with any Analog device of your choosing.
Unread 11-02-2008, 14:48
Originally Posted by Joe Johnson View Post
*if you have a PID control you are living on the edge if you don't have routines in your C code called "JustEnabled" and "justDisabled" You should have those routines anyway but you REALLY need them with PID control. JJ
I can't agree more. We just call our controllers when the robot is enabled. Dead simple and works great.
Unread 11-02-2008, 15:28
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
hahaha
thanks for that.
I think the same way... and so therefore there is no official programming mentor who actually looks over my code anymore (=
i would advise against using a pot for PID control, because the pot will always be returning to the same position, and the brush inside the pot will wear down on the resistive material, which would sacrifice the signal's validity. Im not saying that something like a joystick wouldnt do this, but a joystick is a lot more replaceable than a robot.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 15-02-2008, 18:33
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I guess I am comfused and I have been trying to get an idea on all this. I wish to be able to move the joystick to say a value of 200, then I want on the robot a motor to turn an arm until it also reads another pot at the same angle.
Example:
Joystick tilted slightly forward, thus arm tilted slightly down.
I cant figure out do I use a PID loop or do I just get creative with some other code or use a table? In the past I would just use limit switched but II want better control this year and a more varied location.
-Mike
Unread 15-02-2008, 19:05
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Use the sample code that has been bandied about in this thread, but instead of setting Target with conditionals and hardcoded values, just set Target equal to the value coming in from your joystick axis, or some function of that value (for instance, target=p1_y*4; would give you access to the full range of the pot). Does that make sense?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-02-2008, 23:03
Mike AA's Avatar
AKA: Mike Aalderink
Do I have to use Kevin's ADC code added somewhere within my code or could I just copy the code from Dustinb_3?
Any help is greatly appreciated the robot is about done but we've been busy on that and waited til the last minute to work on completing the code.
-Mike
Unread 15-02-2008, 23:18
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Example:
-Mike
Do a simple proportional control...
arm_motor = (arm_pot - p1_y) * 50;
dont multiply by 50, multiply by something that actually makes the arm move smoothly.
RPI 2012
BREAKAWAY
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Potentiometer Theory Ulibrium Technical Discussion 6 25-01-2002 21:16
