Go to Post Any mentor worthy of a WFFA would be delighted to see one of their fellow mentors receive the award. - dtengineering [more]
Unread 20-01-2007, 23:24
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mystery Sprockets
Originally Posted by aaeamdar View Post
Our mentors have told us that normal operation of the wheels places significant wear and tear on the wheels such that you really should use the steel sprockets. However, if you know this isn't the case, could you elaborate further?
The wheels use rather large sprockets, with many teeth, and usually the chain wraps more than half way around the sprocket, so the load on each tooth is relatively small. The aluminum sprockets are strong enough for use on wheels, and the smallest size you can commonly get is 24 teeth, I believe.
However, the transmission sprockets are a different story. Some use as few as 9 teeth, so the load per tooth is significantly higher.
The general way of doing things is to use steel sprockets at the drive end of the chain, and aluminum sprockets at the wheel end of the chain. It works.
tachometer mystery? Issues Motors 31 27-11-2005 20:44
pic: 930 Mystery Teaser Gamer930 Robot Showcase 3 14-02-2005 12:03
mystery theater help hollieteam388 Chit-Chat 0 21-01-2004 17:45
Mystery Science Theater 3000 Ryan Dognaux Chit-Chat 3 18-08-2002 16:49
mystery icons Joe Johnson CD Forum Support 2 07-06-2001 22:09
