Go to Post If people really want to see "better" refereeing, they should see what they can do to help FIRST make better. - petek [more]
Unread 20-01-2007, 23:59
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: pic: Servo Controlled Valve
Originally Posted by Nate Laverdure View Post
Interesting and novel idea, but I can't think of a use for it.
And does this violate <R99> (customizing pneumatics components)?
NO. No modification of the valve occurred. It is simply a "knob turner". The valve's knob was NOT modified, and it is retained within the box only via the SMC connectors (no leaks!).
Gee... I see that CDF put the pic up before I had a chance to add my comments. (Wow! 99 views already while I typed!) Please look at the text now supplied, for construction and usage notes.
I hoping that this design may be found useful for:
-- a rookie team with limited budget for real control valves,
-- someone wishing a non-piloted valve for vacuum or low pressure cylinder apps (below what kit valves can control),
-- a team that wishes to make a Starting-to-Operating configuration transformer setup, without wasting an expensive kit valve for the purpose,
-- any application where you need to isolate a subsystem (IOW prevent something from working) from start of round until the desired critical moment, or
-- stopping a cylinder in a mid-position, by plugging the vent port.
BTW, if you DO replicate this in some version, PLEASE drop me a note to tell me your mods, and how you used it! Good luck with your build!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
PC Controlled Robot EHaskins Programming 6 05-11-2006 06:45
pic: pneumatic actuation of ball valve Andrew Schuetze Extra Discussion 2 30-10-2006 08:40
Camera Controlled Robot douglass1371 Programming 1 19-02-2006 19:22
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servos controlled by RC? Obi Programming 5 01-02-2005 14:43
