Go to Post Jeez, I love my job! :) - dlavery [more]
Unread 21-01-2007, 08:19
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Editable Mesh vs. Editable Poly?
I'm a little confused about pros & cons of Editable Mesh vs. Editable Poly. It looks there are more editing tools available when you convert a object to an Editable Poly.
Are there any advantages Editable Mesh has over Editable Poly?
Unread 21-01-2007, 09:08
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
Re: Editable Mesh vs. Editable Poly?
Most people (me included) use Editable poly instead of editable mesh... But it's really up to you...
Poly seems to be an "upgrade" of mesh tool, since (if my memory doesn't fail) it was introduced at 3dsmax v4, and it has more tools, BUT the key difference is how mesh and poly will convert the same object.
Mesh will converty every polygon into a group of triangles, and will show it to the user. Poly won't show the triangulation of the object to the user, making the modelling easier...
Just note that meshes have the sub-object "face", that selects polygons according to their triangulation
This is what i learned. It may be wrong, who knows? =)
And i don't speak english, so please don't complain about my grammar =P
Unread 21-01-2007, 09:14
Christian Christian is offline
FRC #0408 (RoboTicks)
Christian will become famous soon enoughChristian will become famous soon enough
Send a message via AIM to Christian
Editable mesh is mainly used for exotic shapes and objects. Meshes are composed of triangles, and geometry class has taught us that triangles (or any three points) are flat and will render properly. Editable poly is used for dealing with shapes, polygons if you will. With polys, you introduce space. When you get above three points, you can have some variation along th z axis (if you are using the x and y) that will make it render improperly because that polygon won't be flat. If you ever noticed an edge or vertex shading to black, or black holes in your object, this is your problem.
My advice, work with editable poly, thats what I use. I don't like editable mesh personally. But if you get any of the above errors, switch to editable mesh.
Here are some links that will help out:
http://forums.cgsociety.org/showthread.php?t=3034
http://www.webreference.com/3d/lesson114/
President/Programming/Mechanical/Electrical/Animation/Website
robots and cake are all you need, everything else like oxygen are considered bonuses.
Unread 24-01-2007, 09:19
Mike200's Avatar
Mike200 Mike200 is offline
FRC #0375 (Robotic Plague)
Team Role: Animator
Mike200 will become famous soon enough
Send a message via AIM to Mike200
Editable Poly is a step up from editable mesh. However, editable mesh allows you to create a stack of modifiers. So for instance, if you were creating a human from one mesh, you can place the arms, torso, legs, head, etc. all on different layers in the same object.
Unread 24-01-2007, 10:21
vadyr's Avatar
vadyr vadyr is offline
103 Alumni/Mentor - FIRST Volunteer
AKA: Bobby
no team (Cybersonics (Mentor))
vadyr is a jewel in the roughvadyr is a jewel in the roughvadyr is a jewel in the rough
Send a message via AIM to vadyr
I am more of "the texture guy" on our team, but I know most of our modelingis done with editable poly. It seems to be more universal, easier to form things, and much more "user friendly" (which 3dsmax is generally not...heh). I guess what I'm trying to say is that they have different functions, and you have to choose which one fits your idea best.
www.cybersonics.org
Unread 24-01-2007, 20:37
Testament-Doom's Avatar
Testament-Doom Testament-Doom is offline
The wanderer of all worlds.........
AKA: David Perrot
None #0555 (Team 555)
Testament-Doom is a jewel in the roughTestament-Doom is a jewel in the roughTestament-Doom is a jewel in the rough
Send a message via AIM to Testament-Doom Send a message via MSN to Testament-Doom Send a message via Yahoo to Testament-Doom
Well, Editable poly seems like the way to go. It has more features than Editable mesh, including paint deformation and all. To me, I always thought of Editable mesh as something advanced users would use. I would prefer Editable mesh if you're dealing with terrain work and such. It's meant for that.
Testament-Doom's 3D art (If you want to check it out) - http://testament-doom.deviantart.com
"It does not matter how easy or hard it was to create your art, but the end result that matters most." - Me.
Unread 25-01-2007, 06:48
AKA: Kevin Thorp
Thaks for all the info. This is a great forum!
Unread 29-01-2007, 18:56
raymaniac's Avatar
raymaniac raymaniac is offline
meE wEr HeER
FRC #0116 (Epsilon Delta)
Team Role: Animator
raymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to behold
I've never really looked into editable meshes. When I started, I was told to stick with editable polys, so I've pretty much ignored the existance of everything else.
Everyone have fun at the regionals Atlanta. Or else...
Vote for 116's animation!!!
Unread 29-01-2007, 22:09
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
I've met people who swear by NURBS and they try to animate with them. (shudders)
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 29-01-2007, 22:21
AKA: David Perrot
Good luck for them.
Unread 30-01-2007, 11:20
AKA: Kevin Thorp
I also researched this question on "professional" Max forums. The consensus is Polys are generally much more useful, but Meshes still have a couple handy features, like an accurate face count.
Some people will convert a poly into a mesh then back to a poly many times in an editing session. Evidentially there's no loss of going back & forth.
Unread 30-01-2007, 12:58
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Don't rule out NURBS entirely, they can come in handy when you try to do any complex surface modeling. Infact, there are NURBS based software programs such as Rhino3d that are actually quite good at what they do. You can even download a fully functional trial of that program that stays activated for your first 25 saves.
I'm lovin' me some NURBS.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 30-01-2007, 17:32
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
I do aggree that NURBS are extreamly good at making organic models and complex surfaces like that. The trouble comes when you try to rigg NURBS.
A.K.A Llama
Unread 30-01-2007, 17:37
raymaniac's Avatar
meE wEr HeER
Team Role: Animator
That is exactly why we try to stay away from organic stuff in our animation.
New Team to be (Possibly) Started at Cal Poly Pomona A. Leese Starting New Teams 13 10-03-2005 01:51
Problem w/Mesh Kevin Thorp 3D Animation and Competition 4 17-02-2005 23:04
3D Wire Mesh Ryan Dognaux 3D Animation and Competition 5 04-02-2003 14:00
omniwheels on steel mesh mickjagger Technical Discussion 14 26-01-2003 22:45
Mesh/ramp question BerserkerSpyke Rules/Strategy 1 18-01-2003 11:48
