Accelerometer Code
I’m having trouble finding the accelerometer’s code for this year or last year’s Accelerometer.
Can someone tell me where it is? Thanks, Tal |
Re: Accelerometer Code
If you need it for the regular C then go here->2005 FRC code Repository It's somewhat old but you should be able to modify it. It has the full ADC code built it but it would be better if you take Kevin Watson's ADC(new one not the 2005 one) code and integrate into it, this way you can use other analog sensors simultaneously. Last edited by 6600gt : 21-01-2007 at 15:41. |
Can someone help us by publishing the accelerometer code that is modified to work with the dual-axis accelerometer? P.S. Kevin said last year that he will publish the code, but I can't seem to find it either. Thank you for your help. Tal, Neat-Team |
JFYI: easyC has the code built in.
-Kevin |
-Kevin |
#7
If you'd like, I also developed some code for using the accelerometer (for tip sensing or for position/velocity sensing). The code can be found in my old post here:
http://www.chiefdelphi.com/forums/sh...82&postcount=5 It works with Kevin's 2006 ADC code so you can use it with other analog sensors. I'm currently working on modifying it to support dual and triple axis accelerometers for our robot this year, I'll post up the new versions when I have them finished. |
| Does anyone has code for accelerometer? | sjung9442 | Programming | 2 | 30-01-2006 21:37 |
| Accelerometer code?! | David55 | Programming | 2 | 25-01-2006 01:15 |
| Accelerometer code | ImmortalAres | Programming | 28 | 04-06-2005 01:02 |
| Some things i'm trying to understand on Kevin's Accelerometer Code | Squall | Programming | 2 | 03-02-2005 12:01 |
| Example accelerometer code released. | Kevin Watson | Programming | 0 | 20-01-2005 03:45 |
