Go to Post There are simply not enough words to say how much the contributions of Dave and Woodie have given to FIRST, and countless students across the world. - Libby K [more]
Unread 21-01-2007, 02:47
brennerator brennerator is offline
brennerator is an unknown quantity at this point
How do you cheesehole?
WE dont have a mill or extensive tools. What is a good method to cheesehole into 1/8" thick aluminum box beams?
Unread 21-01-2007, 02:52
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: How do you cheesehole?
Hole saw and a hand drill is the easy way to go, though not the prettiest. Our team has access to a mill and doesn't need to cheesehole; however the emergency method is to start drilling holes. Also, just ask around to use someone else's drill press and cheesehole, as it's not a tiring as doing it with the hand drill.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
We have a drill press; but we would like to drill 2 inch holes.
Unread 21-01-2007, 02:53
AdamHeard's Avatar
Lead Mentor
Then put a 2" holesaw in the drill press...
Unread 21-01-2007, 09:52
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Rotex punch! but it only works on flat stuff, or the flange of an angled part. You can't put tubular sections in it.
Unread 21-01-2007, 10:47
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Yup put a 2" hole saw in the drill press, apply a lot of cutting fluid or grease and just starting chopping. It will probably make a sound like somebody is dying but you've just gotta go with it.
Team Website
Unread 21-01-2007, 10:50
DonRotolo's Avatar
Back to humble
FRC #0832
Safety Warning: NEVER use a hole saw in metal with a hand-held drill! It CAN be quite dangerous!
A drill press with a 2" hole saw would be fine. Time-consuming, but not difficult.
Learn how to sharpen the hole saw and keep it sharp, every 25 holes or so.
Don
Unread 21-01-2007, 10:51
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
And make sure to clamp down what you are cutting.
Unread 22-01-2007, 11:21
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
waterjet
Unread 22-01-2007, 11:31
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
Last year, a friend and I cheeseholed our shooter by using a uni-bit on a regular hand drill
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
Unread 22-01-2007, 13:09
Jetgrindradio00's Avatar
Jetgrindradio00 Jetgrindradio00 is offline
Jesse Laufer
AKA: Jesse
FRC #0580 (Campbell Hall Vikings)
Jetgrindradio00 will become famous soon enoughJetgrindradio00 will become famous soon enough
Drill a bunch of little holes with a hand drill?
Unread 22-01-2007, 13:47
Ianworld's Avatar
AKA Ian Ferguson
AKA: Ian Ferguson
I wouldn't recomend doing a lot of little holes with a hand drill it will take you forever.(a 1/4" hole in 1/8" thick aluminum weighs all of .0025 pounds) One thing you can do however depending on the material you're cheese holing is to drill a couple small holes and then jigsaw them into nice large cutouts. You just have to be careful to not remove too much material this way since it can be easy to get off track with a jigsaw.
Team Website
Unread 22-01-2007, 14:05
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We have a mill, but decided to cut out square portions of our chassis with a jigsaw to keep the weight down. Milling would take too much time due to the length of the sections that need to be removed, and we only have one somewhat small and cramped mill/lathe. Ideally, we have 3 or 4 jigsaws so more than one person can work on cutting the pieces out at a time.
The way I cut out a square section in the middle of a sheet of metal is to drill a 3/8" hole on the corner points of the square, so you can fit the jigsaw blade in there to make the cut.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 22-01-2007, 19:54
Nick E Nick E is offline
Robotics, eh?
FRC #0888 (888)
Nick E is an unknown quantity at this point
Send a message via AIM to Nick E
^^^That's what I think is the easiest method..But..If you have access to an oxy/accetylene torch, you could probably do it pretty quickly..Not sure how well it would do with aluminum though.
Unread 22-01-2007, 20:06
MrForbes's Avatar
AKA: Jim
plasma cutter.
How do you feel toward you robot? Rickertsen2 General Forum 48 07-03-2006 00:37
How old were you when you got your first real job? Ashley Christine Chit-Chat 31 24-08-2005 13:58
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
