Go to Post If I find a student on my team who came through FIRST having learned nothing more then he wanted to go to MIT, I'll give my self a pat on the back and start counting down to kickoff. - Andy A. [more]
Unread 20-01-2007, 22:35
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
Bottoming out on ramps?
Apparently ramps are going to be very common this year. With this said, what are your ideas on how to prevent your alliance robot from catching their chassis on the corner of the ramp (the transition from sloping ramp to platform parallel to the ground). Our robot may have a simple middle wheel on each side raised sightly above the drive wheels which will work on any degree ramp (as long as the front wheel can get to it). Though, not all teams may incorporate something to get similar results. I was thinking a roller at the transition, but this isnt as simple as one can say. So your ideas??
Thanks....
Steve
Unread 20-01-2007, 22:37
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
Re: Bottoming out on ramps?
ours is going to be high enough off the ground to make it up a ramp. As long as it is not extremely steep, i am not sure of the exact degree.
Unread 20-01-2007, 22:41
16 degrees, give a take a degree.
I've just been reading how some are designing with a mere 2-3 inch ground clearance with a max climb angle of 14 or so.
Just want to make the bot is as universally adaptable and acceptable for everyones needs, 'cause you never really know what your going to get until your there.
Unread 20-01-2007, 22:43
We designed for a 30 degree ramp.
Unread 20-01-2007, 22:45
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Isn't that going to be very difficult for teams with compromised traction such as teams with omni wheels or swerve drives?
It shouldn't be a problem for teams with six wheel tank drives or tracks.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 20-01-2007, 22:54
Exactly. It will be hard, but ive worked up a pretty much slip resistant design for the ramps, its just that transition which we are all pretty stumped on
Unread 20-01-2007, 23:09
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
This is a very intersting point, especially as it relates to climbing 12" high ramps.
We're designing with 4" ground cleareance (in the center), which allows for a ramp as steep and high as last year (which happened to be 12" high). I forget the angle, but I believe it's a bit more than 30 degrees.
In the end, regardless of how you do it (ground clearance, skid pad, 6 wheel drive, etc...), you definately want to keep ramp climbing in mind (assuming you're not the ramp!).
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 20-01-2007, 23:19
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There are some things you can do...the ramp can have a rounded or multi-angle transistion. Part of the platform could sit higher than 12", to make it easier to get on, and still keep the angled part of the ramp kind of short. Some commercially available motorcycle ramps are rounded near the top to ease the transition, see if you could copy the design.
Unread 20-01-2007, 23:22
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
We've designed a 4 wheel drive system which is very much centered at the front of the robot, with the back being supported by casters. That way, even if we do bottom out we will be able to drag ourselves up a ramp with the front wheel drive.
As for our ramp, we have allowed for a shallower angle than last year's playing field, and we hope to round the top corner.
Unread 21-01-2007, 10:22
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Right now, our ramp is just under 17 degrees. Our 2005 bot had 2 inches of ground clearance and it seems to be able to climb it fine. We may change the design, so the angle will be closer to 13 or 14.
Unread 21-01-2007, 10:25
MrForbes's Avatar
AKA: Jim
we did a quick angle calculation last night, 11.5 degrees, but that is caused by some interesting geometry considerations in our tenative design.
Unread 21-01-2007, 10:45
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
our robot is fairly low clearance, probably not enough you climb a ramp, but like perviously said we should be able to drag ourselves up with our front wheel drive, we are going to be lifting most of the time anyways, so maybe we wont have to
Unread 21-01-2007, 11:46
DDAwg3's Avatar
DDAwg3 DDAwg3 is offline
AKA: Scott
FRC #0549 (LHS Devil Dawgs)
DDAwg3 will become famous soon enoughDDAwg3 will become famous soon enough
This reply is for rockahawk. If you were here, you would know that we have a1 1/2 clearance to the frame and the ramp is 17.13 deg. Whick is not less than 17. Knucklehead.
Unread 21-01-2007, 12:18
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Our ramp(s) wont have a "peak" or transition to go over....think about that!
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 21-01-2007, 13:45
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
That's what I was thinking...
Why not use a curved ramp? A transitional ramp with an intermediate slope between the ramp and platform? Both would reduce the corner and make the transition easier.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
ramps for robotics rijo664 Technical Discussion 2 16-01-2007 11:12
Ramps ideas Andrew Schuetze Technical Discussion 2 14-01-2007 01:20
Gate Ramps KWB@FIRST General Forum 14 17-10-2006 23:38
Sticking Ramps and Fat Goals! archiver 2001 5 24-06-2002 01:47
Overall Dims of ramps & field from CDI 1999 archiver 2000 0 24-06-2002 00:08
