Go to Post If anything, I believe Battle Bots is in the best interest of FIRST. Battlebots helps to create an interest in robotics, and FIRST gives us the opportunity to participate in a robotics program. - Adare180 [more]
Unread 21-01-2007, 10:14
itay_ms itay_ms is offline
FRC #2215
itay_ms is an unknown quantity at this point
Simulating autonomous mode - i need help!! :(
Hi, im kinda nooby with the programming so id apreciate if u help me, i noticed that in the main function the condition for autonomous mode is that autonomous_mode will have a value, but can i control this value in order to make the autonomous mode work so i can see the whole camera thing working?
i realy hope im making sense here and that someone will help me.
Thank you for your time!
Unread 21-01-2007, 10:26
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Simulating autonomous mode - i need help!! :(
Rather than directly manipulating that variable (can be dangerous* if you forget to remove the code), what we did last year was something like this:
if(autonomous_mode || p3_sw_trig)
This way, it would still work normally in competition, and if we had a joystick connected to port 3, we could trigger it at will.
*The reason this is dangerous is simply if you lock autonomous_mode to 1 then forget to remove it later (it can happen, trust me), your team will be angry at you because your robot never left autonomous mode. Likewise, if you hardcode it to 0, then your team will be angry because your autonomous mode never worked. The or I propose here allows you to simply attach a joystick to port 3. Once you're done, just put tape on port 3 saying "programmers only" so that no-one triggers it by accident.
The ideal way to do this is to make a competition port. However, I know very few details about how to do that, so someone will have to post details on that.
Unread 21-01-2007, 10:56
FRC #2215
well, the thing is, i totaly understood what u posted but i dont understand something a lot basic than that, i dont understand what determines the value of autonomous_mode in the first place, it seems logical to me that we will have a switch that determines if the robot is in autonomous mode or regular mode, so how can i determine the value of autonomous_mode? or am i jsut getting it all wrong lol
Unread 21-01-2007, 10:57
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
The value of autonomous_mode is set by the main field computer, its totally out of your control. It happens automagically.
Unread 21-01-2007, 11:00
Electrical Engineer
Rookie Year: 1995
Itay,
The best way is to leave the code alone and build a competition port dongle.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 21-01-2007, 11:28
FRC #2215
Thank u all guys uve helped me a lot, i got what ur saying now, i guess id knew that if it wasnt our first year in FIRST good to have so many ppl helping.
Auto mode... need help teh_pwnerer795 Programming 15 20-02-2007 11:32
Autonomous mode chs938 Programming 1 03-02-2006 10:19
need help with autonomous caderader Programming 3 14-02-2005 18:25
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
Autonomous mode Tyler Olds General Forum 30 22-02-2004 14:31
