Go to Post Fear the power of the custodians! - Fixen [more]
Unread 21-01-2007, 11:03
Re: Potentiometer PID
Originally Posted by NextPerception View Post
i would do this
      if ( (Button1 * Button2) + (Button2 * Button3) + (Button3 * Button1) + ( Button1 + Button2 + Button3 ) == 1 )   //prevents crazy values if more than one button is pressed and keeps the same value if no button is pressed
            Target = (Button1 * 200) + (Button2 * 400) + (Button3 * 600)
this just makes more sense to me and I just post it here for any like minded people out there. I think it takes a little less cpu time too.
It makes sense if you're averse to using procedural programming and prefer functional programming. The logic behind your code gives the same result as the one using if statements, but the reason for doing it that way is obscure to anyone encountering it cold.
And it takes a lot more time to do it your way. A few comparisons and branches are faster than many multiplications and additions. Note that the original code never does more than three comparisons and one assignment. Yours always does six multiplications, thirteen additions, and one comparison. It would be instructive to compile both alternatives and compare the generated assembly language code in the listing file.
As an aside, wouldn't it work just as well to simplify the condition to this?
if ( ( Button1 + Button2 + Button3 ) == 1 )
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Potentiometer Theory Ulibrium Technical Discussion 6 25-01-2002 21:16
