Go to Post It is better to err on the side of caution than to put yourself in a position to have a referee or judge make a call against you. Build smart! - Sean Schuff [more]
Unread 19-01-2007, 19:13
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
Window Motor
Can someone tell me the Rpms on the window motor from the kit thanks
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 19-01-2007, 19:42
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Window Motor
http://www2.usfirst.org/2007comp/oth...0Practices.pdf
See page 8.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2007, 19:55
run the trap!!!
Team Role: Human Player
Re: Window Motor
Another Question.
How robust is the window motor?
We rigged up a prototype arm last weekend and we think the spur gear stripped. As it turned out, we were overloading the motor. We added a piston to ease the load. With the piston in place, there is little strain on the motor, but I am still worried that a sudden shock could break another gear.
Has anyone had any experience with this motor stripping?
(I'm talking about the worm-drive inside the case, not the steel gear on the output shaft.)
-Philip J. Fry
Unread 21-01-2007, 11:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Window Motor
Could you please give us an idea of what kind of load you had on the motor, to make the gear strip? I assume you had an arm attatched to it somehow, could you give us a rough idea of how long the arm was, how much weight was on the end of it, how heavy the arm itself was (or just the resulting moment, if you want to keep the details secret). Also did you have any additional reduction between the motor and arm, such as a chain and sprockets?
Thanks in advance....we're considering using a window motor to drive a chain reduction system that would lift an arm. If the window motor can't take the torque load, then it won't work very well!
Unread 21-01-2007, 12:58
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Window Motor
The worm in this motor housing is made of plastic, so a sharp impact on its shaft could certainly strip it.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 21-01-2007, 13:00
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Window Motor
I to would like to know the load at which you stripped the gear.. we are also planning on using the window motor to power our arm and a weight restriction would be nice!
Window Motor Moonlightic Motors 1 17-01-2007 07:56
Window Motor Calvin Motors 9 21-02-2005 17:04
Window Motor Info... tenfour Motors 4 24-02-2003 23:34
Window Motor Gear?? BBFIRSTCHICK Motors 6 03-02-2003 14:09
window motor archiver 1999 0 23-06-2002 21:52
