Go to Post The great thing about posting questions here is everybody can see the answers. - Kevin Thorp [more]
Unread 21-01-2007, 11:51
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
WPILib Questions
Is it possible to send commands to the camera using the serial port calls in WPILib, or will the response from the camera (ACK/NCK) confuse the library? I assume that the library handles any incoming bytes from the camera. The reason I ask is that I wanted to use the Virtual Window function on the camera.
Steve
Unread 22-01-2007, 11:46
AKA: Brad
#0190 ( Gompei and the Herd)
Re: WPILib Questions
Steve
I put up a new version of WPILib that exposes some of the internal functions that can reset the camera and send commands to it. Should make it easy to use the Virtual Window stuff.
http://users.wpi.edu/~bamiller/WPILib/Versions.html
Please let me know how it works and if it solves your problem.
When you reset the camera, then send commands, tracking is turned off. You need to restart tracking by calling StartCamera(). Also you can set the camera debug mode by calling SetCameraDebugMode(1) and the commands to/from the camera will be echoed in the terminal window so you can see what it is doing.
Brad
Brad Miller
Robotics Resource Center
Welcome to the WPILib forum BradAMiller Programming 22 25-03-2008 22:44
New version of WPILib BradAMiller Programming 26 27-01-2007 15:49
Using WPILib on a Vex robot koenig3456 Programming 2 02-05-2006 14:56
Use of printf in WPILib koenig3456 Programming 2 06-03-2006 07:21
