Go to Post A person is not defined by what mistakes they make, but more so by what they do after they realize their mistake. - Andy Baker [more]
Unread 08-01-2007, 11:34
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
opening up the BaneBot gearbox to install the CIM motor
Note that the hex key required to remove the end plate on the BaneBot gearbox is a metric size 2.5mm.
An American size hex key will not fit, and may damage the allen head cap screw on the gearbox.
You can buy such a hex wrench at
McMaster Carr:
mcmaster.com
Search for part #: 7289A13
This is a ball-end wrench, which will speed things up a bit when loosening and tightening the screws.
Cost is $0.26.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 10-01-2007, 10:08
Brandon Holley's Avatar
Re: opening up the BaneBot gearbox to install the CIM motor
I got it off with an english allen wrench no problemo
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-01-2007, 13:37
None #0612
You won't be able to tighten it up sufficiently if you use a 3/32" hex key. Better to get a 2.5mm key.
Also, the bolts that hold the motor to the plate take a 4mm key.
Also - beware that on several transmssions the black spacer that goes between the CIM motor and the pinion gear is a bit too long. Grind or turn it down by 1mm or so before installing it.
Unread 11-01-2007, 20:31
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We only stripped one screw. I got it off fine with our ball-end 2.5mm allen wrench, but someone else tried an english allen wrench and stripped one screw. Is there any way to get it out? I thought about drilling it out, but that might damage the gears.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-01-2007, 21:41
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I got some out with a 3/32" but most where to tight so I had to find my metric set and use a 2.5.
Unread 20-01-2007, 19:26
Skute327 Skute327 is offline
AKA: Alex Symington
FRC #0871 (Robotechs)
Skute327 has a spectacular aura aboutSkute327 has a spectacular aura about
Send a message via AIM to Skute327
We stripped a few of these screws, Anyone know where to get replacements? I checked Banebots site but all I could find were 10-32's and 1/4-20's
Unread 20-01-2007, 20:57
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
The directions stated to use a 2.5 metric allen wrench. Beware of the correct size to all the KOP items. Some are metric and some are regular. The shaft size will be different also on a lot of the motors.
Unread 21-01-2007, 12:56
None #0612
You can buy more at:
www.mcmaster.com
Search for 'cap screw', then select metric.
If you are in California, try:
http://www.fastener-express.com
Unread 21-01-2007, 23:53
Mechanical/Driver
Any suggestions for getting out a stripped screw? I'd hate to order another gearbox because of one screw...also what size are the replacements?
Unread 22-01-2007, 11:12
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
There are places that specialize in broken bolt removal, at least there's one around the corner from me. They might be able to use an Easy Out or another specialized tool to get the bolt out.
Another possibility is to find someone who can use some form of EDM, Electrical Discharge Machining. This will literally burn the screw out, but without damaging the threads.
You could also drill out the screw, and thread the larger hole for a threaded insert. Keensert is one brand. The insert reduces the hole size back to what it was originally.
Christopher H Husmann, PE
"Who is John Galt?"
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Gearbox that can be used inline with a CIM bombadier337 Motors 3 11-03-2005 22:05
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
Can anyone confirm that the CIM and Drill motors are the same as last year? Jeremy Technical Discussion 2 12-01-2004 21:54
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
