Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 07-01-2007, 20:31
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Re: Rack Construction
Originally Posted by Phantomechanics View Post
so unless you buy and make your own the only "rack" available for testing is the one at the competition sight?
You should consider contacting other teams in the area and seeing if any of them wants to build a mutually owned rack with your team. You could also see if a local team already building a rack wouldn't mind your team trying it out for a little while just to see what it's like in person.
Unread 07-01-2007, 20:42
Phantomechanics's Avatar
Phantomechanics Phantomechanics is offline
phantom mechanics
AKA: joey
FRC #2028
Team Role: Student
Phantomechanics is an unknown quantity at this point
Send a message via AIM to Phantomechanics
THANKS seriously....that's a good idea...we'll do that...
Unread 07-01-2007, 20:51
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
Well, we have a rack but what good is it if there are not enough ringers and keepers to go around. Can I find a supplier of the rings on the FIRST website? If not, can somebody tell me where we can order some more. Thanks.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Unread 07-01-2007, 21:31
Team Role: Driver
Starting on wednesday, you can order tubes from FIRST. I think that there is a limit on the number of keepers that each team can purchase, but you could just use ringers with tape on them or something like that.
Unread 08-01-2007, 15:21
AChastain's Avatar
Thanks alot. I was lost in this new FIRST site.
"You On!"
Unread 08-01-2007, 16:14
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Don't worry, a lot of us are.
Unread 08-01-2007, 16:20
Michael Hill's Avatar
Here is what I'm getting to build the field for 1646
Item	Quantity
Wood
4' x 8' x 3/4" Plywood	4
2" x 4" x 8' SPF	19
2" x 4" x 10' SPF	8
4' x 8' x 1/2" Plywood	2
1" x 2" x 2' Pine Board	4
4' x 8' x 1/4" Plywood	1
Hardware
3/8-16 x 3 1/2" Carriage Bolt	32
Flat Washer, SAE 1/4"	184
1/4" x 2" Hex Head Lag Bolt	56
1/4" x 3 1/2" Hex Head Lag Bolt	80
Screw, Wire Eye, 7/32" x 15/16" THD.	8
Nut, 3/8"-16 Nylon Locking	32
Screw, #10x2" Decking	32
Screw, #10x3" Decking	104
Eye Bolt, 1/4-20 x 1" THD	54
Flat Washer, 1/4" Fender	6
Coupling Nut, 1/4"-20 x 7/8"	3
Coupling Nut, 1/4"-20 x 1 1/2"	24
1/4"-20 x 3 1/2" Hex Head Bolt	24
Threaded Chain Connector	48
Screw, #8 x 3/4" Wood	96
Screw, 1/4"-20 x 1" Flat Head	48
2/0 Twist Link Machine Chain	70'
Rubber Tiedown Strap (14")	4
Pipe
2" x 5' SCH-40 PVC Electrical Conduit	24
Oatey PVC General Purpose Drain	24
5/16" ID SAE J30R7 Fuel Hose	20'
Kligotti's Avatar
Kligotti Kligotti is offline
Rensselaer Polytechnic Institute
FRC #1124 (UberBots)
Kligotti is on a distinguished road
I have just finished figuring out all the materials and the estimated amount of each material needed to built the rack. If anyone would like this information (I have it in a spread sheet form) please feel free to email me at kligotti@comcast.net.
Also, on it i have some places to get the materials and the estimated costs, although some of these materials can be gotten at many different places.
Unread 09-01-2007, 20:49
Zack Zack is offline
FRC #1051
Team Role: Driver
Zack is an unknown quantity at this point
Smile Re: Rack Construction
Originally Posted by Cory View Post
Here is our list. We did not purchase the fuel hose for the finger, or the tie down straps for the bottom piece to limit it's movement. We planned on using latex tubing or something.
Thank you!! You have just save me hours of pain trying to figure out all the supplies my team needs.
Unread 21-01-2007, 13:23
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Does anyone have any idea on the dimensions for the light arm? We are assuming it is the same length as the spider legs, but we cant figure out what angle the light is mounted at. Any help??
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 21-01-2007, 13:36
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
The light arm is cut at 10 degrees - it is part B on this sheet:
http://www2.usfirst.org/2007comp/Dra..._OF_2_Rev6.pdf
Eric
Unread 21-01-2007, 13:47
thank you!!
~kim~
Modeling The Rack. Eric Scheuing Inventor 22 16-01-2007 19:51
pic: Wooden Rack Wetzel Extra Discussion 3 07-01-2007 16:33
Rack n Roll Animation Joe Matt General Forum 1 06-01-2007 14:28
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
Rack OakCrewz OCCRA 3 12-11-2002 22:05
