Go to Post A good thing to do when thinking about designs like this, ask yourself "what do I gain?" - lemiant [more]
Unread 21-01-2007, 13:24
dawilliams dawilliams is offline
FRC #2028
dawilliams is infamous around these partsdawilliams is infamous around these partsdawilliams is infamous around these parts
Ringer Dimensions
ARENA Section 6.3 says, "When inflated, each GAME
PIECE is approximately 32 inches across the outer diameter. Each toroid has an inner diameter of
approximately 13 inches, and a height of approximately 9-1/2 inches."
Is anyone else having trouble that the ringers supplied in the KOP don't match the dimensions shown? Ours measure 8.5" height.
Unread 21-01-2007, 14:18
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Ringer Dimensions
We had a similar problem until we pumped our tubes up to the maximum PSI. At 2.5 PSI the tubes measure a perfect 9 1/2 by 9 1/2 inches.
We filled the tubes to this pressure using a sensitive pressure gauge and the KOP compressor.
pic: Full Scale Prototype Ringer Arm 2007 lynca Extra Discussion 5 20-01-2007 00:25
pic: Ringer Supported by Both Spider and Stinger Nate Laverdure Extra Discussion 7 17-01-2007 15:45
Ringer pressure Seki Technical Discussion 2 12-01-2007 19:13
pic: 2 ringer spacing Ryan Foley Extra Discussion 3 07-01-2007 01:31
pic: Spoiler and Ringer on top leg 2 Ryan Foley Extra Discussion 1 07-01-2007 01:25
