Go to Post I'm gonna go back to my corner and write some more code... - Kevin Watson [more]
Unread 21-01-2007, 06:47
itay_ms itay_ms is offline
FRC #2215
itay_ms is an unknown quantity at this point
cam not working with CMUcam2GUI
im connecting the cam to the computer and in the CMUcam2GUI but the softwere noy found the cam
Unread 21-01-2007, 11:55
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
Re: cam not working with CMUcam2GUI
Make sure the backup battery is fully charged, make sure the camera is plugged into the PWM but IS NOT plugged into the TTL. Make sure the camera is on. Should work!
Unread 21-01-2007, 14:26
slloyd slloyd is offline
AKA: Sonny
FRC #1221 (Nerbotics)
slloyd is an unknown quantity at this point
you also need to plug a DB9 cable between your camera and the back of your PC.
with these cameras you can either view the picture of the captured video (via the DB9 connector) ... OR ... use the TTL converter and no DB9 to track a green light.
eh?
Unread 21-01-2007, 15:17
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
also make sure that your computer is reading the port used that it is connected to and select the right port.
When you plug it into the camera, go to control panel --> System --> Hardware --> device manager look at the COM and ports and see where its plugged in. You have to tell the GUI where to look for the camera.
Unread 22-01-2007, 07:59
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Ok, we got the GUI working, did grab frame etc. What are we supposed to do now?
Unread 22-01-2007, 10:58
Just use it to focus the camera.
You can also see and measure the camera's field of view for yourselves.
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
cam not working :( magical hands Programming 3 05-02-2005 21:45
CMUCam not working Inverted Programming 10 04-02-2005 19:32
Radios not working... E Jones 234 Electrical 3 21-01-2005 21:58
CMUCam not working. Matt Krass Programming 4 18-01-2005 14:08
