Go to Post Remember there are many eyes watching and often you are judged by what you say and how you say it. - Mike Martus [more]
Unread 20-01-2007, 17:46
groovy69 groovy69 is offline
groovy69 is an unknown quantity at this point
MPLAB 7.20 Help please?
hi there, when i use mplab and go to project > build all, it always creates a ".coff" file not a ".hex" .. any idea how i might go about fixing this? many thanks
Unread 20-01-2007, 19:25
Re: MPLAB 7.20 Help please?
help
Unread 20-01-2007, 20:39
taberski taberski is offline
FRC #1619 (Up-a-Creek)
taberski is an unknown quantity at this point
You need to get MPLAB to run MP2HEX.
In MPLAB IDE 7.20 select:
Project->Build Options ... ->Project
and select the MPLink Linker tab,
Finally - check the INHX32 Hex-File Format.
Good Luck!
Kevin Taberski
Software Mentor
Team 1619 - Up-a-Creek Robotics
Longmont, Co
Unread 20-01-2007, 20:43
Electrical Engineer
Rookie Year: 1995
I do not know how you are managing to do this. From MPLAB select Project>Build Options>Project and click in the MPLINK Linker tab and then verify that INHX32 is selected. My guess is that this is not your problem...
My guess is that you are getting an error which is halting the build process...
Any error messages?
Mike
Mike Betts
As easy as 355/113...
Unread 20-01-2007, 20:46
slloyd slloyd is offline
AKA: Sonny
FRC #1221 (Nerbotics)
slloyd is an unknown quantity at this point
i had this problem when the project we were editing was burried very deep in the directory tree. try closing down MPLAB. copy your entire working directory, then paste it somewhere near the root directory such as:
C:\mcc18\projects\{working folder}
then open your workspace again in MPLAB and try build all function.
slloyd
Unread 20-01-2007, 20:53
Christian Christian is offline
FRC #0408 (RoboTicks)
Christian will become famous soon enoughChristian will become famous soon enough
Send a message via AIM to Christian
I also had this same problem and as slloyd said, the project was burried very deep. I just created a directory: C:/camera and put the project in there. Then, changed the output directory to that path since it was still creating the .coff file after the directory change.
President/Programming/Mechanical/Electrical/Animation/Website
robots and cake are all you need, everything else like oxygen are considered bonuses.
Unread 20-01-2007, 22:52
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
After you go Project -> Build All -> Project, you go to the MPLINK Linker tab and check "Suppress COD file generation." That worked for me.
Unread 21-01-2007, 11:58
wow thanks so much for the help everyone .. you're all so much friendlier and willing to help than id expected ... again many thanks!
good luck to you all!
Unread 21-01-2007, 12:13
Originally Posted by groovy69 View Post
...you're all so much friendlier and willing to help than id expected ...
Welcome to the world of Gracious Professionalism. Helping each other out is part of the culture we're trying to spread. Soak it up and pass it along. While FRC teams are certainly rivals, we are not enemies.
Unread 21-01-2007, 12:20
Absolutely.
and ya, here's what i get now when i build...
MPLINK 3.94, Linker
Copyright (c) 2005 Microchip Technology Inc.
Errors : 0
MP2COD 3.94, COFF to COD File Converter
Errors : 0
MP2HEX 3.94, COFF to HEX File Converter
Errors : 0
Loaded C:\frc_camera_21\camera.cof.
BUILD SUCCEEDED: Sun Jan 21 12:17:30 2007
and its building a hex. so thanks a lot
-out of curiousity should it still say .cof? here: Loaded C:\frc_camera_21\camera.cof.
Unread 21-01-2007, 14:17
AKA: Sonny
glad to help
Unread 21-01-2007, 15:23
another problem now.. in the com1 terminal window.. it doesnt display any of my printfs... which is puzzling...
essentially this is all i want to see:
rot = Get_Analog_Value(rc_ana_in01);
temp = Get_Analog_Value(rc_ana_in02);
pot = Get_Analog_Value(rc_ana_in03);
ac = Get_Analog_Value(rc_ana_in04);
printf("rot: 3%d, temp: 3%d, pot: 3%d, ac: %d/r", rot, temp, pot, ac);
Unread 21-01-2007, 15:34
The carriage return character is \r.
Unread 21-01-2007, 18:31
^ omgosh .. bleh what a small and terrible error on my part.. thanks for catching that..
-however, it still does not diplay anything in the com1 terminal window..
maybe this will help:
when i unplug the frc controller from the main power (12V) the com terminal window prints: IFI>
it does this once for every time i unplug, then plug back in, the power to the controller...
hmm??
------ and it seems like everytime i turn around im getting some new error---
any help?
INK 3.94, Linker
Error - section '_entry_scn' type is non-overlay and absolute but occurs in more than one input file.
Errors : 1
BUILD FAILED: Sun Jan 21 18:30:34 2007
Unread 22-01-2007, 02:00
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
http://www.chiefdelphi.com/forums/sh...ad.php?t=51256 This thread has information on the '_entry_scn' error.
Help with MPLAB burningpig Programming 9 17-01-2007 13:10
Please help; HUGE mplab problem brennerator Programming 5 09-01-2007 01:25
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
PLEASE HELP US FIND OUR MOMMY (or MPLAB) superlou Programming 3 23-02-2004 16:33
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
