Go to Post ...remember RAID 0 is a trap. - Sperkowsky [more]
Unread 21-01-2007, 11:01
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
Globe Motors
Hi,
I have a small question. Are we allowed to you use more than one globe motor on our robot? I couldn't find any restriction regarding it, so it is quite ambiguous....
Thanks,
Guy
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Unread 21-01-2007, 11:06
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Globe Motors
I have an additional question relative to the globe motors, sorry its not related to the above post but does anyone know how they handle direct drive cantilevered loads.
I understand cantilevered loads aren't usually in good practice, but it might be slightly unavoidable in this situation, and I was wondering how that bronze bushing holds up under load. Also without wanting to pull it apart, is there another bushing/bearing inside the motors planetary gearbox or is the one viewable the only one?
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 21-01-2007, 11:08
iR3 Creative
AKA: Dan Richardson
Re: Globe Motors
Ohh by the way According to Paul C. in this thread, the motors and quanties are listed below
The motors you can use (and their respective quantities) listed:
QTY 4 2.5" CIM Motors (2 in the kit plus 2 for purchase)
QTY 2 3" CIM Motors, aka the Mini-Bike motor (1 in the kit plus 1 for purchase).
QTY 2 Globe motors (both in kit only)
QTY 2 window motors, the shiny ones with RH / LH (both in kit only)
QTY 1 Denso motor, the other window motor (in kit only)
QTY 2 Banebots motor (in kit only)
QTY 2 FP motors (in kit only)* - this one is still pending a clarification since we received 2 but the list states 1.
The total is 15. Of course, direct replacements are O.K. for any of the motors (if one breaks), but the only motors you can use in larger quantities than provided in the kit are the 2.5" CIM and the 3" CIM.
Unread 21-01-2007, 11:15
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Globe Motors
Update has clarified FP motor discrepancy...now lists 2 to match the 2 we all got to start with...
Unread 21-01-2007, 12:06
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Re: Globe Motors
It is my understanding that the Globe Motor's attached gearbox is easily damaged by side loads. We have been warned about this often in the past. I've not read something this year, but it has been in previous documentation and I believe the motor is the same from previous years.
Good Luck!
-Mr. Van
Coach, 599
The RoboDox
Unread 21-01-2007, 13:03
FRC #1574 (MisCar)
Re: Globe Motors
Does the Globe motor tend to heat when static load is applied on it?
Is it suitable for static load ?
Visit our website:
www.miscar1574.com
Unread 21-01-2007, 14:33
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Globe Motors
Our team has modified the planetary gearing on these motors for the last two years, as they one of the few motors that you are allowed to modify or remove the gearing.
There is only one bronze bearing which cannot support thrust loads (in and out), but can accept some side loading (like a gear or sprocket) as long as the object is mounted on the transmission output shaft itself.
Overall these motors are great little gearmotors, and I'm very happy to see that the KOP included two this year. They have never quit on us and they do not overheat as much as other motors.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 21-01-2007, 14:43
Re: Globe Motors
The Globe motors as others have pointed out, can handle very small side loads. Unfortunately, when the bearings start to fail they go fast. I have not seen these motors used in real life with any significant side load or large diameter gears on the output shaft. They are reliable when protected.
Unread 21-01-2007, 14:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Globe Motors
I wonder if the Globe would be able to withstand a sizeable side load, within 1/2" of the bronze shaft bushing, if the end of the shaft were well supported with a ball bearing.
Unread 21-01-2007, 15:39
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Globe Motors
Gabe is correct in his description of the internals of the gearbox. That bronze bushing is the only support on the output side of the gearbox. By supporting the outboard side of the shaft, you will have two properly supported ends. This type of setup should handle pretty much any load you can throw at it.
I'm not sure I've heard of anyone stalling a Globe motor and burning it out. This motor has so much torque that it has basically ripped through our mechanical stops in the past. We always use limit switches/pots with these motors.
Good Luck,
BEN
Unread 21-01-2007, 16:53
MrForbes's Avatar
AKA: Jim
Re: Globe Motors
Thanks, I was at the hardware store, a 1/4" id x 5/8" od ball bearing is readily available, and since it's od is the same as the end of the motor, it should be possible for us to make two plates that will keep it all in line relatively easily.
If the chain will fit in the available space, and leave room for mounting the sprocket, that is.....
[OCCRA]: Globe Motors woody OCCRA Q&A 1 14-10-2006 14:52
globe motors arabsponsor Motors 16 29-01-2005 00:12
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe Motors? Brett W General Forum 3 10-01-2003 21:13
Globe Motors archiver 2000 1 24-06-2002 00:15
