Go to Post You wrote a PID control loop for your coach? Whoa. - meatmanek [more]
Unread 21-01-2007, 17:17
tcj103 tcj103 is offline
AKA: Ted Jones
None #0486 (Positronic Panthers)
tcj103 is on a distinguished road
Intermittent CODE ERROR, followed by uncommanded relay switching
We've encountered an intermittent problem with this years robot controller. We have the 2007 streamlined camera code on the robot, as provided on Kevin Watsons web site. Once in a while, we'll power up the robot, which will set a "code error" on the controller. Then, if you hit the reset on the controller, everything seems to reset OK, the code error light goes out, but then a spike relay will start cycling at about 1 Hz, sounding like an old car turn signal. Turning off the robot, and starting back up, sometimes will clear the condition, but most times it wouldn't. Moving the joystick all the way to one side (I think to the left) makes the relay stop. I'm not sure if the trigger still operates the relay (we modified the Kevin.org code for relay controls and some PWM control shaping)
The other symptom during this time that prior to the reset, the main battery voltage indicates OK on the controller (over 12 VDC). But when the relay is clicking, the battery power display shows about 8.2 VDC, even though during that condition, we metered the battery terminals, as well as the power going into the controller, and got over 12 VDC.
So, can anyone explain the incorrect battery voltage? I'm looking through IFI reference documents, but haven't found anything yet. We have since reloaded the streamlined code, with fewer changes, and are waiting to see what happens. To my knowledge, we're using the firmware on the controller that came with it, no updates have been loaded that I know of.
Also, I found one explanation about code error, is there a more detailed description of it anywhere?
Thanks
Ted
Unread 21-01-2007, 17:26
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Intermittent CODE ERROR, followed by uncommanded relay switching
Are you using timers or interrupts in any unusual or extensive way?
Also, the 8.2-8.3v problem is one that showed up last year and everyone hoped was gone this year. Guess not.
Check out http://www.ifirobotics.com/docs/memory_problem_8722.pdf
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 21-01-2007, 19:07
AKA: Ted Jones
Thanks for the tip!
We are not using any interupts or timers, beyond what the camera code uses from Kevin Watson.
The 8.2-8.3 V problem sounds more like firmware/hardware. Can operator software cause this problem?
I'll check to see if they've complied with the memory problem update.
Unread 22-01-2007, 01:56
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
The key to soliving the problem that was showing up last year (with symptoms similar to yours) was the change in the linker script. The 8.2-8.3 problem was found by our team to be temperature sensitive (occuring more often when the processor was cold, and less when it was warm).
The problem seemed to occur when the memory used by txdata and rxdata (the memory used to communicate between the master controller and the slave controller) was in the memory section adjacent to the hardware registers. The linker script patch makes that piece of RAM protected so it is not used (and the memory used for communication is moved away from the hardware registers).
Unread 22-01-2007, 02:59
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Thanks
Ted
As others have mentioned, this is a nasty bug that some folks have had problems with. Grab a copy of the 2.1 camera code and extract the *lkr and *.lib files into your build directory. Make sure you use the new library when you re-build.
-Kevin
Kevin Watson
http://kevin.org
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Intermittent Code Error Plloyd Programming 9 09-04-2005 21:37
Help with auton switching code farmer Programming 3 15-02-2005 15:30
C++ Code Error? Adam Shapiro Programming 9 20-01-2003 13:24
Relay Connection Figure 2.2 in error ? Lloyd Burns Technical Discussion 6 31-01-2002 16:04
