Go to Post FIRST, in itself, will not make you an engineer. - RogerR [more]
Unread 15-01-2007, 12:58
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Green light same color as overhead light
When ever we take a frame of the green light with our new CMU2 camera we have a problem. The green light appears as teh same pixel color as the overhead lights above (white).
I have attached a frame.
If anyone knows what is going on their help is much appreciated.
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 15-01-2007, 13:11
something something is offline
FRC #1438
something is an unknown quantity at this point
Re: Green light same color as overhead light
You probably just need to turn down the brightness
Unread 15-01-2007, 13:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Use YCrCb instead of RGB Colors and turn off Automatic Gain Control.
Unread 15-01-2007, 14:13
You have accidently discovered that fluorescent light changes color at a 120Hz rate. Part of the time it is green and part of the time it is blue. Your eye integrates the color flicker into a single color since your eye can only see this motion at less than 24 times a second. Correcting for white balance or using some of the other techniques discussed in the documentation will help.
Unread 16-01-2007, 13:14
kevin.fort kevin.fort is offline
President-Team 1001
FRC #1001 (Hacksaw Robotics)
kevin.fort is on a distinguished road
Send a message via AIM to kevin.fort
We have the same problem with our camera. We work in the autoshop so it hits the overhead shoplights and locks onto them. We fixed the problem artificially by making the tilt not go as high as the overhead lights
We build our bots with hacksaws
websites too: http://hacksaw.brush.googlepages.com
Unread 16-01-2007, 13:42
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
See this post and thread for a possible solution to try:
http://www.chiefdelphi.com/forums/sh...4&postcount=23
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 22-01-2007, 00:18
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Ethulin, that is exactly the kind of picture we got this morning after completing the build of our target light. This is with a brand new 2007 camera.
The target showed up as 240,240,240. So did the non-reflective calendar on the wall. So did the flourescent lights in the next room. We tried using the adjustments mentioned in the LabView manual but those did not help at all. We also tried adjusting several different values in LabView with no luck. I had to leave before we could spend more time on it.
I have searched several threads and have not found any actual working values posted.
EDIT: I just noticed that Kevin Watson's page contains a workbook with complete calibration procedures. Looks like I need to do some reading.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 22-01-2007, 01:53
Originally Posted by Keith Watson View Post
The target showed up as 240,240,240...
That's what it looks like in RGB values. Switch to the YCrCb color space and you'll find it looks very different from nearly everything else the camera might see.
Unread 22-01-2007, 03:04
Kevin Watson's Avatar
La Caņada High School
FRC #2429
You shouldn't need to do any calibration. Please see the FAQ for details: http://kevin.org/frc/camera.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2007, 07:09
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Well it was strange, but we did have to calibrate ours to get it to work. Not much though, but still...
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 25-01-2007, 19:51
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
We've tried the default "bells and whistles" code both with and without calibration, and no such luck. We can achieve a constant tracking confidence in labview of over 200, but we transfer these settings through the camera menu, it can't find the target at all. Without any calibration, we can't find the light either, even though all the documentation says we should be able to.
We're in a fluorescent-lit shop, but the target is convieniently located in between some shop lights. We've tried Eldarion's tips with saturation AND darkening/diffusion filters, but these haven't worked when running through the RC either. They work great through Labview though.
If it helps at all, the lights are a full pink in Labview, and the light is barely different
I'm just about ready to give up on the camera... Too bad I need it for the AI-controlled driving we were planning on making...
Unread 27-01-2007, 11:45
abrockhoff abrockhoff is offline
Team 11 Programming Captain
AKA: Alex Brockhoff
FRC #0011 (MORT)
abrockhoff will become famous soon enough
Send a message via AIM to abrockhoff
The programmers on team 11 did change some of the values from default. We lowered the saturation and brightness, along with tweaking some other values.
Kevin's code did work, but when we started working in a room with bright flourescent lights the camera picked them up too.
Now we basically when we take a picture in labview, we see a black screen and nothing is highlighted other than the green light.
..and make sure you're in YCRCB not RGB.
Unread 06-02-2007, 09:14
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We're out on the shop floor as well. Using Kevin's default camera code, and experiencing the exact same thing.
First, let me say "Thanks Kevin!!!!". Without your code, we never would have even touched the camera. (Or the encoders... or the gyro.....) Our lack of dedicated "controls" guys makes things very tough at times.
Anyway - our rack is made out of 2x4's and PVC. The overhead lights are sodiums. Our camera with the default code is picking up the green light, the reflections of the overhead lights off the 2x4's, and the overhead lights as well.
I'm going to spend sometime with labview to see if I can tweak it away from that. It is making our whole team very very nervous. We know the play areas are VERY brightly lit, and with the end plates on the racks being diamond plate - we're worried that we're going to get a lot of very nasty reflections when you're facing the target.
Unread 02-08-2007, 15:24
LVfan LVfan is offline
LVfan is an unknown quantity at this point
I agree you need to make sure to be in YCRCB and not RGB
Check out VI Roadshow
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
KOP green light 987HighRoller Kit & Additional Hardware 1 13-07-2006 23:18
pic: Green Light Dermot_135 Extra Discussion 17 19-01-2006 18:02
Green light box demensions? pheNIX637 Kit & Additional Hardware 2 11-01-2006 15:14
Green Light Rachika Garcia Kit & Additional Hardware 1 10-01-2006 08:46
