Re: Need help building the rack!
Hope this helps. |
I've not seen the drawings, so I may be way off, but whenever I've seen "TYP" in a drawing, it's meant "typical(ly)" ... where on the drawing is "14.912' TYP"?
TYP on a drawing means that that dimension applies to multiple dimensions on the drawing.
For example, if there is a circular pattern of 8 bolt holes to be drilled on a drawing, the diameter of one of the holes might be dimensioned as 0.250" TYP, which implies that dimension would apply to all 8 holes, even though only one was labeled. |
| Items need to build the Rack!!!! | Micahrules | Technical Discussion | 1 | 08-01-2007 18:11 |
| help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) | liad | LabView and Data Acquisition | 8 | 18-01-2006 12:20 |
| Building the field - Vision tetras (PLEASE HELP ME) | capenga | General Forum | 6 | 25-01-2005 18:54 |
| Need help on informations (THE ARM OF THE ROBOT) | Ryu | General Forum | 13 | 13-10-2004 00:06 |
| Notes on building the Square Rack | archiver | 2000 | 1 | 24-06-2002 00:06 |
