Re: Extension Cables - keeping connected
we used eletrical tape which we still had a couple problems with but we found if you can get the close to a stationary object or at least stays straight like a piece of metal zip tie both side down tight. that seemed to work for us but only because we had something to zip tie to. I also agree losing a match because a PWM slips out is not fun it happened to us in the semis at a scrimmage and then in the finals at the socal CSUN competition.
I'm not sure if it would work, but try placing a strip of non slip mat over the cables and fasten it down on both ends, the holes int he mat should expand enough for the cables to go in, but should close enough to keep the cables in.
I've never tried that, but it could work, otherwise zip ties are the only vex legal way to go unfortinately ![]() |
The rule comes from the FRC side. Electrical tape can only be used as an insulator. No tape, of any kind, can be used to join components together. Engineering doesn't involve duct tape. ![]() |
the idea that skimoose suggested is similar to tied the cable down to a stationary part with two zip-ties at both end. this rule make us think of a way around it.
. but using tape seem convenient, too. |
I think Mark had the best soultion, tie the junction in a simple overhand knot and use a trywrap to hold the whole thing together.
| <R86> No more than one motor may be connected to each speed controller. | Michael Hill | Electrical | 2 | 08-01-2006 02:00 |
| Camera not working when connected to robot | MarkVH | Programming | 5 | 14-02-2005 15:40 |
| Camera not working when connected to robot | MarkVH | Programming | 2 | 05-02-2005 18:08 |
| Acceleration Sensor Connected, but values are odd.... | Leav | Electrical | 7 | 04-02-2005 15:28 |
| Fisher price motors connected to the relays? | zainali | Motors | 1 | 09-02-2004 18:50 |
