Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 22-01-2007, 12:58
nasa-senpai nasa-senpai is offline
FTC #1492
nasa-senpai is an unknown quantity at this point
Inventor software trouble/ FIRST Base trouble
When you guys downloaded and installed Autodesk Inventor, where you able to get Autodesk Mechanical (It was part of the Autodesk Inventor package)?
One more thing, about the error involving having a flash player too current for Autodesk Inventor to load, how did you solve it? I tried what it recommended, but I didn't get anyware.
Unread 22-01-2007, 15:36
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Inventor software trouble/ FIRST Base trouble
Here is a tutorial on our website about installing Inventor, which does address the flash player issue. You basically have to uninstall it using the uninstaller from Macromedia's site (link in the tutorial) since it doesn't even show up in Add/Remove Programs. Then, finish the Inventor installation, and when Firefox/IE prompts you to install flash player the next time you visit a flash page, install it as usual, and Inventor still seems to work fine.
http://www.andersonrobotics.com/www/wiki/CadSetup
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 24-01-2007, 09:15
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
In general, there shouldn't be any problems with Flash Player and Inventor. Error 1406 while installing is probably the most common issue with installing Inventor...here is Autodesk's page on solving the problem:
http://usa.autodesk.com/adsk/servlet...linkID=4183228
Mechanical Desktop should install along with Inventor. If you're having problems, you can install Inventor without Mechanical Desktop, and once Inventor is working, come back to the setup program any time and install Mechanical Desktop.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
trouble getting to the FIRST site? Al Skierkiewicz General Forum 13 10-01-2005 12:04
KK in trouble??? Jon K. Chit-Chat 5 09-10-2004 19:49
I/R trouble!!! Cadetdan Programming 19 16-02-2004 19:00
trouble... archiver 2001 0 24-06-2002 01:39
trouble... archiver 2001 1 24-06-2002 01:39
