Go to Post People... chill. It is week 1. Recall week 1 last year when many teams said "no one is capping with the 2x ball"... "only a few teams are hanging". - Andy Baker [more]
Unread 22-01-2007, 13:10
Ian_Xodus Ian_Xodus is offline
FRC #1896
Ian_Xodus has a spectacular aura aboutIan_Xodus has a spectacular aura about
PID How to hold an arm in a fixed position without a locking gear box
I have read a little of the PID stuff and i sort of get it. I am wondering a few things.
1. How does your team power the rotation of their arm and get it to stay in a lifted position?
2. Do you use the window motors or some of the smaller motors to power its rotation and lifting?
3. is there not a risk of burning up a motor if just barley enough voltage is applied to keep an arm lifted?
This is my second year in FIRST... Im not sure that the robot my team produced lastyear should be considdered something FIRST worthy. I really need help or pictures.
Unread 22-01-2007, 13:37
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: PID How to hold an arm in a fixed position without a locking gear box
1. You can write a very simple piece of code that will do a decent job of keeping your arm up. Store your target potentiometer position, and set your motor output to 127, plus the target, minus the current position. (Or the other way around, depending on which direction is up.)
2. A window motor can lift a small arm. For bigger arms, you'll want to look at the RS-540, the FP, or the CIMs. The Good Practices document will tell you what torque is available without additional reduction, and what your peak power is.
3. Some motors burn up, others don't. FPs have a reputation for letting out magic smoke at stall, whereas CIMs have a reputation for being essentially indestructible.
Feel free to post if you have more questions.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 22-01-2007, 13:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How about the globe motor? can it take the heat?
(we are planning on loading it at about 20% of it's stall torque spec)
Unread 22-01-2007, 13:42
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
I don't know of any cases of motors burning up without being at or close to stall. I do know that the Globe gearboxes start to break if you sideload them.
_
Unread 22-01-2007, 13:45
MrForbes's Avatar
AKA: Jim
Thanks, that's reassuring! We're aware of the side loading issue with the Globe, and I think we can support the shaft properly without too much work, after thinking about it for a week.
Unread 22-01-2007, 13:56
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Make sure to set the victor your motor is hooked up on to the "brake" setting; this will make it more difficult to back drive and will make the motor better keep your current arm position.
Also, the type of system you use to move your arm can automatically help keep your arm stable. Screw drives are basically impossible to backdrive, but you're limited to less than 180 degrees of rotation with them.
Using some of these things may make it unnecessary to keep a PID loop in programming monitoring the position of your arm.
Unread 22-01-2007, 14:30
MrForbes's Avatar
AKA: Jim
We are working on different designs using either the globe, BB, or window motor(s). The globe looks to be the closest to what we need as far as torque capacity and rpm, but the others are there as backup if it doesn't work.
Unread 22-01-2007, 14:46
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
And to pile on with another idea: A common solution to preventing back drive is to interface your motor with a worm gear, if possible. You just need to make sure whatever motor you use can withstand axial thrust. I believe some of the KOP motor transmissions utilize worm gears (i.e. the window motors)...
Unread 22-01-2007, 14:56
MrForbes's Avatar
AKA: Jim
The window motors do use worm gears, although they are a bit weak (torque) compared to the globe and BB motors. But two window motors can work together if needed.
Unread 22-01-2007, 23:33
EStokely's Avatar
EStokely EStokely is offline
AKA: Eric Stokely
FRC #0360 (Revolution)
EStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond repute
Or using a "big" motor, CIM as an example to do the main drive of an arm and use the window motor for its anti back drive feature in conjunction, it won't add much to lift but locks position pretty well.
BTW globe motors back drive pretty easily with seemingly little forces on them
Eric Stokely
Team 360 The Revolution, past mentor of 258 The Sea Dawgs
Experience is what you get when you don't get what you want.
Unread 23-01-2007, 00:12
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Globemotors are indestructable little things that can take the heat, even when stalled. (Don't do it just for fun, though)
I love GlobeMotors!!!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 23-01-2007, 10:00
MrForbes's Avatar
AKA: Jim
The plan is to have the arm motor mounted "up high", so weight is a big concern....less weight up there means less tendency to tip. Adding a remote drive system to it also adds some weight "up high", but not as much as putting a CIM up there.
But that is an interesting idea of combining two different types of motors to drive the arm, thanks!
We did an experiment with a Globe using a wrench and a scale....the Globe will back drive with about 1/5 the load we plan to apply to it, so this could be a serious problem.
Unread 23-01-2007, 11:02
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
We used the two motor solution a few years back with an extendable ladder like structure. The trick is to make the window motors holding direction so that you are driving the armature toward the back of the motor. I.e. hold the motor in your hand and if the output shaft is facing you and the motor part is to the right and up, the stopped load you would want turning the output shaft clockwise. We have had very bad luck with the holding load the other direction. The other thing is to match the free speeds of the two motors you are using. The published info is good. Hooking them up and counting revolutions is even better. In 2005 A Globe and the Keyang window motor was a good match. We had a coupler with 16 teeth for #25 chain machined the linked the two shafts together. It was the best working part of the arms on that robot. And it stayed where you left it with out driving power. This year you get two Globes and two Keyangs. I will attach the inventor file. We did have some issues with the machining and had to do some of it by hand.
Biff
Unread 23-01-2007, 11:06
MrForbes's Avatar
AKA: Jim
Thanks for the tips! I'll get my son to open the inventor files....I'm not that computer literate yet
Unread 23-01-2007, 16:45
FRC #1896
Thank you for all of your input but my question has still not really been answered.
do you guys build your own gearboxes for the globe motors?
Do you use any special programming to make the motor stay slightly engaged to keep the arm up?
Do you use globe motors, van door, or window?
Sorry... only my second year in first.
PID without a Ph.D. Joe Johnson Programming 3 07-02-2006 17:37
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
how do you hold pins in? archiver 2001 4 23-06-2002 23:45
How do teams hold their brainstorming meetings? Anton Abaya General Forum 10 03-01-2002 18:02
