Go to Post Slight physical blocks will never stop a good programmer, we can just program around it. - AIBob [more]
Unread 22-01-2007, 19:14
kborer22's Avatar
kborer22 kborer22 is offline
kb
AKA: kb
FRC #0125 (Nutrons)
kborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud of
Send a message via AIM to kborer22
Modifying 40 Amp maxi fuse block
this year we plan on using 4 small cims in our drive train and a FP cim for our arm. From my understanding its technically a FP motor so we can use a 30Amp breaker. But by looking at the torque curves of the motors using the 30 A fuse limits us to 140 oz-in of torque as opposed to 240 oz-in of torque with a 40A breaker. So we have been playing around with the 40 Amp maxi panel and we "reconfigured" it. So now we have one full fuse panel and a second one that only has one terminal. Does anyone know if we are allowed to make this modification?!
NUTRONS 125
2007 Boston Regional Champs (125, 126, 69 NU-Hyper-Force!)
MORTTeam 11
2004-Palmetto Regional Champs
2004-Palmetto Regional Daimler Chrysler Team Spirit Award
2005-NJ Chairman's Award Winner
Unread 22-01-2007, 19:16
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Modifying 40 Amp maxi fuse block
Unless something has changed, you MUST use the maxi block for all CIM motors.
Unread 22-01-2007, 19:20
kborer22's Avatar
kb
AKA: kb
FRC #0125 (Nutrons)
i was looking at some threads from last yr and from what they said you could use the Big Cim on a 30A if you wanted. And in the wiring diagram they have the FP motors going to the 20/30 A panel. But regardless....we would rather use the 40A...does anyone know the rule about modifying the maxi block?
NUTRONS 125
MORTTeam 11
Unread 22-01-2007, 19:32
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
By "modifying", do you mean something like "cutting in half"?
Ill have to check but I dont think you can modify any of the electronics.
Unread 22-01-2007, 19:38
kborer22's Avatar
kb
AKA: kb
FRC #0125 (Nutrons)
if yoru farmilar with the block.....one end is solid and the other ends and individual clips, we removed the big block and now have 2 individual clips....
NUTRONS 125
MORTTeam 11
Unread 22-01-2007, 21:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'll go ahead and guarantee you that this will be illegal, even if it doesn't appear to be now. The breaker panel is designed to be safe in its original configuration. cutting it in half will be viewed as rendering it unsafe, and the part will be declared illegal. FIRST is pretty serious about keeping teams from accidentally attempting arc welding with a poorly wired robot.
Unread 22-01-2007, 21:38
Price Vetter's Avatar
Price Vetter Price Vetter is offline
AKA: Electrical_Fire
FRC #0418 (LASA Robotics)
Team Role: Electrical
Price Vetter is an unknown quantity at this point
Send a message via AIM to Price Vetter
Even though it is a FP motor it is also concidered a CIM motor and therefore must use a 40AMP breaker.
Although there may be no rule specifying that you can't modify the breakers it's more than likely illegal.
Unread 22-01-2007, 21:49
Adam and Price,
A. He's asking if he can modify the Maxi panel, not if he can protect a Bike Motor with a 30 A.
B. You're wrong. You can protect a speed controller with whatever breaker you like, and you can then use that speed controller to power whatever motor you want.
<R97> Speed controllers may be protected by 20A, 30A, or 40A circuit breakers. Speed controllers may power motors or devices of any size.
Doesn't get any clearer than that.
Unread 22-01-2007, 22:02
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Thanks, Kevin; I agree that is perfectly clear.
Back to the original question:
<R46> prohibits "Fuse panels different from those provided in the Kit Of Parts." Modifying the maxi block would render it different, so you can't do that.
Richard Wallace
since 2003
Unread 22-01-2007, 22:07
Right...but you still cannot power any CIM motor through any thing less than a 40A Breaker...correct?
Unread 22-01-2007, 22:12
Read <R97> again. You can protect a speed controller with any breaker. Say 20A. You can then hook up whatever motor you like to this speed controller that's protected with a 20A breaker. Even a CIM. This may not be intelligent in any given situation, but I've seen a lot of legal, unintelligent things on robots.
Richard,
Thanks, I figured there was a rule that applied directly, but couldn't pick the right one out of so many options.
Unread 22-01-2007, 23:11
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
kb isn't really clearly describing what's being proposed.
If you look at the Maxi panel, the big brass pieces are attached to the plastic with little screws. We're wondering if it would be legal to remove the unused brass, not cut, nodify or otherwise destroy the breaker panel. No parts will be damaged, and everything on there will be original, it would just be without a few pieces of brass. There's no inherent reason why doing this would be unsafe, and we're not doing anything that anyone with a phillips head screwdriver couldn't do.
Unread 22-01-2007, 23:16
If it came with the brass, and you have you unscrew things to remove it, you're modifying the part and it's not the original anymore. I completely sympathize with the notion, and 57 is looking at powering some FP motors with 30A breakers just to avoid this same problem. It just doesn't look legal from reading the rules this year and experience from years past. You're more than welcome to ask on the Q&A, however.
Unread 23-01-2007, 08:16
kborer22's Avatar
kb
AKA: kb
FRC #0125 (Nutrons)
yea we have not cut anything, merely reconfigured they set up that it was originally in. On one side there is a single input to come from the new dist block they gave us(the one that slides along that track), and on the other side there are 4 individual clips to hold the other end of the 40A breaker with 4 single outputs to go to each victor. We simply took off the single input block(which shorts together all 4 of the breakers) and using all the original hardware moved another single out put to the input side....
btw....you are allowed to use 30A on cims but depending using a smaller breaker will decrease the amount of torque you get out of motor.
NUTRONS 125
MORTTeam 11
Unread 23-01-2007, 08:20
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Steve,
If I were your Robot Inspector, and I may be, I would render the modified Maxi block illegal. You may appeal my decision to the Lead Inspector, to FIRST, to the Supreme Court, but why take a chance. Make your weight savings in some other area.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Warning! Check the screws on your Maxi fuse block! Roland Electrical 1 16-03-2004 21:59
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
pic: 40-Amp Fuse Block CD47-Bot Robot Showcase 7 20-02-2004 00:23
Maxi 40 Amp Fuse Panel mtrawls Electrical 25 13-02-2004 15:19
