Go to Post The term defensive robot and mechanum wheels do not belong in the same sentence together. - Koko Ed [more]
Unread 22-01-2007, 20:50
proto-man proto-man is offline
None #2254
proto-man is an unknown quantity at this point
Rule <R09> & <R12> contradictory?
<R09>
At the time of inspection, the team must declare in which weight/height class (as specified in Rule <R07>) the ROBOT will be configured for the competition. Once inspected for the declared weight/height class, the ROBOT must remain within the weight/height restrictions of that class for the duration of the competition event. Modifications or changes to the configuration of the ROBOT after the start of the competition that change the weight/height class of the ROBOT will not be permitted.
<R12>
Once the match has started, the ROBOT may assume a PLAYING CONFIGURATION that exceeds the size dimensions specified in Rule <R07>. While outside of its HOME ZONE, a ROBOT may expand up to a maximum width of 72 inches and depth of 72 inches. While entirely inside of its own HOME ZONE, there is no limit to the maximum width or depth of the ROBOT, as long as it remains entirely within the HOME ZONE. There are no height limits for a ROBOT in its PLAYING CONFIGURATION at any time after the start of the match (other than those naturally created by the ceiling height of the competition venue).
Can anyone define competition event? Rule R09 says you CANNOT exceed, while R12 says that you have to stay within 72x72 while on the playing field. Looking around the forums, it seems the general view is of the latter, but I just wanted to clear that up. When they say "competition event", do they not also mean the match?
Perhaps there is something simple I am overlooking because I seem to be the first one asking this question on these forums. Someone else should have noticed this before, right?
Unread 22-01-2007, 20:53
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Rule <R09> & <R12> contradictory?
The height/weight restrictions are for the starting class.
Competition event refers to the competitions and the matches, but other rules may define parts during which the rules are different.
Unread 22-01-2007, 20:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by proto-man View Post
<R09>
<R12>
My understanding of the intent is that they meant to say that robots must remain within the class they declare at their first inspection throughout the event. While in a match, your robot may expand to the allowed footprint of 72 sq. in.
In other words, you can't pass inspection with a 6' tall, 100 lbs. robot and then, in the elimination rounds hack off 2' and add 20 lbs. of balast. That would represent a change of class and is disallowed.
--Madison--
...down at the Ozdust!
Unread 22-01-2007, 20:55
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
They make perfect sense, <R09> is saying that once you register as a 6 ft tall 100 lb robot, you have to stay a 6ft tall 100 lb robot for the rest of the competition weekend.
<R12> is saying that you can expand out of the starting envelope for your particular weight-class once a match starts.
At least that is how I take it...
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
it means when you are getting your robot inspected at the beginning of the regional/nats you have to pick a weight/height category and stick with it but while you are in a match your robot can expand. at the beginning of each match you have to be in the size envelope whether it is 28"x38"x4', 28"x38"x5' ect.
edit: Cody beat me to it.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 22-01-2007, 20:56
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They rules don't contradict. Each class only limits your starting dimensions not the dimensions you may expand to during a match.
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There are three possible weight/height robot starting configurations. <R09> says ou have to pick one, and stick with it, throught the whole weekend. For example, if you build a 110 lb 5ft high robot, you can't add weight to it after inspection, even if you reduce it's height to 4 feet or less.
The 72" x 72" "virtual box" rule applies to robots after play has begun, your robot can expand to any size that will fit within a 72" wide by 72" long by as high as the ceiling box. But you'll have to fold it up again before the beginning of the next match.
also it can be any size when it is in the home zone (although the home zone is only 8 feet by 26 feet, so that is the effective size limit there)
Unread 22-01-2007, 21:03
Gusman1188 Gusman1188 is offline
FRC #0870
Rookie Year: 1930
Gusman1188 will become famous soon enoughGusman1188 will become famous soon enough
Reguarding R12 - I understand that you can't expand more than 72 inches. Does this maximum also count for the arch swing of a mechanical arm for picking up the tubes?
For example, if our robot is 38 inches and our arm expands say 40 inches outside of our robot, would FIRST not allow this? It would be pretty difficult for a robot to get to the top spider with an arm that is shorter than 34 inches if it didn't have some kind of elevation mechanism. Can someone clarify?
Team R.I.C.E. 870
2006 SBPLI Regional Winner
2006 SBPLI Imagery Award
2005 SBPLI Regional Winner
2004 SBPLI Xerox Creativity
2003 SBPLI Regional Winner
2003 CT J&J Sportsmanship
2003 SBPLI KPC&B Entrepenuership
2002 SBPLI Rookie All-Star
Unread 22-01-2007, 21:10
MrForbes's Avatar
AKA: Jim
This question was just answered again on the FIRST Q&A:
"The purpose of Rule <R12> is to define a 72 inch wide x 72 inch deep x infinite height (save as may be practically limited by the venue ceiling height) three-dimensional box. When the ROBOT is not in the HOME ZONE, it must maintain a configuration that will allow it to fit within this virtual box at all times. The virtual box moves with the ROBOT, and the ROBOT may be oriented within the virtual box in any direction. But if any part of the ROBOT, at any height, ever extends outside of the virtual box while the ROBOT is not in the HOME ZONE it will be considered a violation of Rule <R12>. There is no case in which an object measuring greater than 102" horizontally will fit within the 72 x 72 inch limits specified. Any such device will violate the rule if it is used outside the Home Zone."
So, draw a sketch of your robot sitting in a larger square, probably at a 45 degree angle, with the arm stretched out to the opposite corner of the box. Dimension the robot and the box. Does it fit? do the geometry/trigonometry problem....see what happens...it's just like math homework, except that the answer means something!
Unread 22-01-2007, 21:20
DonRotolo's Avatar
Back to humble
FRC #0832
So, what you're saying is that all that Math is useful for something other than taking tests? Wow, whooda thunk it?
Don
Unread 22-01-2007, 21:27
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
perfect sense
once again we have a case of peolple reading the rules but not reading defenitions ( you know the BIG BOLD WORDS )
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 22-01-2007, 21:41
GaryVoshol's Avatar
Cogito ergo arbitro
Don't forget about your bumper dimensions while you're applying ol' Pythagorus.
(since 2004)
Unread 23-01-2007, 00:33
None #2254
Thanx guys. That's what we thought but we just wanted to be on the safe side. Doesn't fare too well if we find out on competition day that our perception of the rules is different from that of FIRST.
heh, now that I look back at it, it does seem pretty obvious
Contradictory FIRST Statements Gobiner Rules/Strategy 10 14-01-2003 16:12
The Sc8 & 9 Rule Joe Matt General Forum 1 08-01-2003 12:50
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
