Go to Post There is always a way, you just have to find it. - Arefin Bari [more]
Unread 22-01-2007, 20:51
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
Cmucam overheating
Hello,
I've been trying to use the cmucam ever since it arrived and it still won't work. I was wondering what you guys think is the problem. I am using Kevin's 07 code, bells and whistles, without tampering with the coding. First the camera jerks slightly when turned on. A red and green Leds (DS1 and DS3) and DS2 flashes on for a split second. the IC above J13 (it should be U8) will becomes warm to the touch quickly after start. The servos also hold the camera in place and resist movement. Any help would be greatly appreciated. Thanks for any help.
Thanks
Team 1555
Unread 22-01-2007, 22:16
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Re: Cmucam overheating
Do the green and red LED's stay on? and what is the outputs? without more info it would seem as though the servos are plugged into the wrong spot, thus getting a constant value of 127 or whatever you set the variables to. sounds like a problem I had last year, everything was perfect except when switching code versions (from the streamlined to bells and whistles) I forgot to switch the tilt and pan pwms, as I had done with the prior, thus they were stuck at a point.
Unread 22-01-2007, 23:08
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
OK, I'll try messing the the PWMs and I'll see if I can get some outputs for you. I'm not able to check now but I'll get back tomorrow.
I'm sorry to say but I am a bad programmer and know nothing about this camera, and I'm the only programmer. So I'll try and give as much info as I can but I may not be able to say it in any coherent manner. And if anyone has a for dummies type of cmucam document it would be greatly appreciated.
Thanks
Josh
Unread 22-01-2007, 23:32
Originally Posted by Oumonkey View Post
...if anyone has a for dummies type of cmucam document it would be greatly appreciated.
http://www.kevin.org/frc/CMUcam2_workbook.pdf seems to be what you're looking for. It was written for last year's system, but it is still applicable today.
Unread 22-01-2007, 23:37
d.courtney's Avatar
AKA: David
reading http://www.kevin.org/frc/CMUcam2_workbook.pdf may help.
A few things to note (some basic things I skimmed over):
to run the camera you need a charged backup battery (although if its not charged the camera's likely not turning on)
calibration is needed in rare cases (extreme lighting, if using kevins code)
and last questions, have you changed kevin's code? if you have, did you try it unmodified? and have you tried easyC, as the name suggests it is easy to learn, its what I am teaching programming on, and use to quickly prototype.
EDIT: Seems Alan beat me to it
Unread 23-01-2007, 02:05
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
I second dumping in kevins code, and plugging your servos on 1 and 2. It pretty much works out of the box, and everyone whos a programming noob thinks its magic.
Unread 23-01-2007, 02:58
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I guess now is the time for me to jump in and promote the CMUcam2 camera FAQ.
BTW, it is magic <grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 23-01-2007, 18:12
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
I'm about to leave and try this stuff. The code was unchanged. I was going to try the easy C stuff. I look in the workbook, but I didn't have time to go through 50 pages of stuff, I want to print it but don't have the place to do that yet. I also looked through the the faq and couldn't find anything useful.
I am going to create a test bed soon so that I can see if it was just some malfunction with out old robot. I also just re download the code to see if thats it even though I don't think I touched it.
And thanks for all the help, its really...helpful!
Thanks
Josh
Unread 23-01-2007, 19:31
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
Well, I tried the code again and it doesn't work. The loader keeps on showing "no camera" I tried both versions of the code without changing it. I am wondering if its the camera itself or if it hooked up wrong. I am reinstalling labview to test it out.
Thanks
Josh
Unread 23-01-2007, 20:42
Bharat Nain's Avatar
Thanks
Josh
Read the book on Kevin's website. Follow instructions VERY CLOSELY and it will work, unless your camera is defective/you fried it. Someone once said, if nothing works, read the manual.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 24-01-2007, 20:22
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
Thanks for all the help, but I guess I let the main reason for the thread to get lost. I had last years camera working but we decided not to use it then. I am still trying to different things to get it to work but that is not a major concern of mine. The overheating of that IC is what I'm concerned about. We are a poor team so to use the camera when its overheating, isn't something we want to do without knowing if its safe. So if someone has any ideas of what to do, or how to fix it, that would be greatly appreciated. Sorry for the Mix up.
Thanks
Josh
Unread 24-01-2007, 22:52
...The overheating of that IC is what I'm concerned about...
Are you talking about the voltage regulator? If it's getting very hot, you might have mounted the camera to the pan/tilt assembly without enough spacers and ended up shorting the board to the aluminum.
How exactly are you powering the camera?
Unread 25-01-2007, 17:49
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
I didn't put the camera together so, thats the first thing I'll check, but I am pretty sure it is elevated but I'm not to sure if that makes a difference. And I'm not sure if its the voltage regulator or not. I'll see If I can find out. I'm about to go so I'll get back on soon, to tell you if its that or not.
EDIT : Well I tried the old camera and the IC, voltage regulator?, still got hot, I removed the casing and it still was hot. I am getting pretty confused right now about it. I guess I should also mention, that this test bed has last years RC. I am currently working on this years RC. But I'd still like some more Ideas or more things to test for.
Thanks
Josh
CMUcam-II Branden Gee Programming 9 18-12-2006 17:41
CMUCam on Vex gabrielse Programming 1 24-04-2006 10:11
cmucam lighting muy dificil Programming 5 22-12-2005 07:49
CMUcam 2 problems KChampion Programming 1 07-06-2005 10:39
Drill Motors....OVERHEATING, DRIVETRAINS! Brian48216 Motors 19 19-03-2003 10:18
