Go to Post So you wanna be a playa But your gear boxes aint fly? You gotta shift us up To get that high speed drive.... - Michelle Celio [more]
Unread 22-01-2007, 23:14
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
FRC #1625 (Winnovation)
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
Electronic Story Boards
We have lots of questions on the electronic story boards. (The team member that knew how to do all this had the nerve to graduate and go to college, so we have all new people on the team this year....)
How do we make the electronic story boards? What web site are we to load them to? I am assuming that it is the teams' main website that should have a link to animation? Is there a place where we could see examples of these story boards?
I apologize if there is a site with all this information on it already. I have tried looking and haven't found one yet.
Thanks,
Carrie
Unread 23-01-2007, 05:46
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: Electronic Story Boards
Hi Carrie,
Here are the rules for the Autodesk Visualization Design Competition: http://firstbase.autodesk.com/?nd=fi..._visualization
You'll need to upload your animation to Autodesk's web site, but post the storyboard on your own.
A Storyboard is just a series of simple sketches showing all the scenes & events of your video. Most of us will sketch out a storyboard on paper, then scan it into the computer. You should create the storyboard first, then use it as a guide to make your animation. That's what "real" TV & film directors do.
Here are a few storyboard examples I found on the Net:
http://www.mercedes.wa.edu.au/Media/howto.html
http://www.polykarbon.com/gallery/storyboards.htm
http://www.rollins.edu/it/video/storyboard2.jpg
Unread 23-01-2007, 18:49
AKA: Carrie Asner
Thanks for the reply! I appreciate the links for story boards.
I had seen the rules for the Autodesk Visualization Design Competition, although it is a little confusing to me also -- it says:
"click on the Autodesk Design Competition area.
An adult member of the team is required to submit the entry for the team. In order to submit the entry, the adult member must be registered on the Autodesk FIRSTbase site.
Click on “Submit Entry” to fill out the entry form.
I can't find a "submit entry" button anywhere. I am registered as a mentor, but obviously I need the mentoring
thanks,
Carrie
Unread 23-01-2007, 20:00
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
do we HAVE to follow these standards (or any other standard)? I'm just drawing my storyboard, its like the examples, but some details my storyboard lacks, nothing really important i think...
thanks for advance =)
Unread 24-01-2007, 07:46
AKA: Kevin Thorp
Carrie: I can't find the "Submit Entry" link on FIRSTbase either. I assume Autodesk will add this soon.
Fernando: I don't think Autodesk cares how pretty your storyboard looks, but note the 3rd point below, under their judging criteria:
Concept (Maximum: 35 points)
Distinction in the use of design and animation to illustrate and communicate a clearly defined message of “Thinking Green”.
Measured in terms of how well your team:
  • identifies and executes on a concept
  • organizes the content for your 30-second animation
  • how well your animation follows your storyboard.
Unread 24-01-2007, 11:05
3dfernando's Avatar
Pixel Transformer
AKA: Old Skull
Team Role: Animator
Well, it says "follows your storyboard", then i think its fine if the storyboard don't look like the standards if the animation follows it well =]
Unread 24-01-2007, 16:18
AKA: Carrie Asner
I received this from Autodesk, Inc and they said I could post it here:
We have not posted the entry form yet. I will send you an email when it is posted.
You do not need to fill out the entry form ahead of time like last year. You will complete this web based form once you are ready to submit your animation. Are you ready to submit your animation entry? The form will be web based and we will not be using Streamline this year.
Hope this helps someone else.
Carrie
Unread 02-02-2007, 18:21
dhorn92 dhorn92 is offline
FRC #1296
dhorn92 is an unknown quantity at this point
I heard that there is an earlier deadline for the story board that is different from the deadline of the animation... Is this true? And if it is, when is it due?
Thanks,
Daniel
Rockwall Robotics - Team 1296 - Rockwall High School - Rockwall Robotics
Unread 02-02-2007, 18:25
AKA: Kevin Thorp
Where did you hear that? You should read the rules (see link above)
Storyboards are due the same date as the animations - Feb. 16.
Unread 02-02-2007, 20:06
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
[/indent]
Great... now everybody will do their storyboards after the finish their animation.
Unread 02-02-2007, 20:10
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Its been a rule for a while.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 02-02-2007, 22:15
FRC #1720
My bad. That should be rendered as "everybody will do their storyboards after they finish their animation."
Unread 04-02-2007, 08:52
3dfernando's Avatar
Pixel Transformer
AKA: Old Skull
Team Role: Animator
since storyboards are concept, it doesnt fit 100% with the final animation... so they would catch those ones who didn't plan before animating...
Unread 05-02-2007, 12:10
AKA: Kevin Thorp
...everybody will do their storyboards after they finish their animation.
That's sort of like drawing plans for a house after it's built.
I wonder why so many people are intimidated by the storyboard requirement?
Unread 08-02-2007, 19:35
FRC #1720
Because
  1. They're not used to doing storyboards
  2. It's a requirement
  3. and they score on how well it fits the animation
Allowable Electronic Parts ptan Technical Discussion 9 31-01-2007 18:54
Paper work and story boards BuddyB309 3D Animation and Competition 3 26-01-2007 22:27
Electronic Signature R.J. Chairman's Award 2 25-01-2006 20:00
Detroit Electronic Expo Raven_Writer Off-Season Events 10 07-11-2003 15:29
5 cylinders, 4 electronic valves Wayne Doenges Technical Discussion 5 27-01-2002 16:14
