Go to Post My strongest FIRST memories, and the teams that leave the biggest impact on me, are teams that seem like they have every reason to give up, but never do. - Chris is me [more]
Unread 22-01-2007, 03:31
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
does anyone have OI and RC radio issues
Hi all,
We hooked up our drivetrain with the OI and RC complete. As we were testdriving our robot so far, we noticed that the radio would go to "no communication" mode and the controllers were basically dead and not controlling the robot. It is intermittent.
anyone have issues or solutions with this problem?
Unread 22-01-2007, 09:44
Re: does anyone have OI and RC radio issues
When the radio doesn't work, the first response should be to tether up and see how things go. If that does not work then you can start to troubleshoot wiring errors, team number settings, dead batteries, etc.
Unread 22-01-2007, 10:14
Best Available Data
FRC #1778 (Chill Out!)
It's not that the radio just loses connection but that the user loses control. Even the disable switch doesn't work. It's my understanding that if the robot loses contact with the OI it should disable itself. It doesn't. The user simply loses control for a short while.
Unread 22-01-2007, 10:19
mcurtis mcurtis is offline
AKA: Maynard Curtis
FRC #1276 (Kaizen Blitz)
mcurtis is an unknown quantity at this point
We also experienced this. At the time, we were running the 2006 OI. Robot seems to be locked in the last data packet sent by the OI. Tonight we will continue testing with 2007 OI to replicate the problem. Because the robot thinks it has good data, disable switch does not work, leading to a very dangerous situation. It seems to happen for a matter of seconds, and return to normal operation. Because of the short duration, and random nature, haven't been able to read the diagnostic lights on the OI. It has not occured with the tether cable.
Maynard
Unread 22-01-2007, 10:42
Electrical Engineer
Rookie Year: 1995
I strongly suggest that you report this problem to IFI.
Mike Betts
As easy as 355/113...
Unread 22-01-2007, 10:50
This sounds similar to last year's "8.2 volt" bug. It never bit us, so I didn't pay close attention to the prescribed fix. I think it involved modifying the linker script to make a bank of memory out of bounds. If nobody pipes up with a good pointer to the details, you can search the forums.
Unread 22-01-2007, 11:10
AKA: Maynard Curtis
I believe it's a problem with the communications. With the 8.2 problem, I didn't see any reference to the disable switch failing. We were using the 2006 OI with the new radios, so it may be a change in the radio communications which causes a intermittent problem. I have notified IFI of the situation. We have the new libs, and linker file installed.
Maynard
Unread 22-01-2007, 13:49
Spider-Man's Avatar
Spider-Man Spider-Man is offline
Curling Rocks
AKA: Adam Jacobson
FRC #0467 (DTB/Shrewsbury Colonials); #0034 (Rocket City Robotics)
Spider-Man has a spectacular aura aboutSpider-Man has a spectacular aura about
Have you updated the Master Code on the 2006 RC?
I believe that the new V13 master code for 2007 has changes for the new radio.
Unread 22-01-2007, 14:06
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Yes, that sounds very familiar!
Also, for those who think the problem may be completely unrelated to the 8.2v bug, remember that when you corrupt a section of memory on a running computer program, the results are (almost) completely unpredictable. A section of memory that is receiving data from the OI may be being corrupted, thereby locking in the last data frame instead of shutting down due to lost radio link.
I wonder if this may be a problem peculiar to your RC, only time will tell.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 22-01-2007, 14:19
AKA: Maynard Curtis
It's the 2007 RC, which I believe has v13 master. Waiting for a return call from IFI. Were getting a "no radio" on the OI. Shouldn't this cause the master to shut down, regardless of what the User processor is doing?
Unread 22-01-2007, 14:32
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Correct, "no radio" should immediately stop the robot dead in its tracks.
Does it work fine tethered??
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 22-01-2007, 16:30
AKA: Maynard Curtis
Spoke with the fine people at IFI. Best guess is it's either a bad cable, or interference from another radio source. There is a half second delay after the last good packet before the robot shuts down. After a good packet is received, the counter is reset, causing an additional half second delay. Hopefully we can narrow it down tonight.
Gamer930,
We have not seen it happen with the robot tethered. It only happens intermittently on the radio.
Maynard
Unread 23-01-2007, 04:30
waialua359's Avatar
AKA: Glenn
we were using the 2006 oi and rc with the new radio's from 2007. Is there a difference with the 2007 oi and rc? we are going to try and run tomorrow with using the 2007 oi and rc and see if there is a problem.
when we lose the radio signal on our oi, the robot stall and shows loss signal also.
cant see how it would be intereference. nothing else around and we have always tested in the same room.
anyone? please help.
Unread 23-01-2007, 07:03
To the best of my knowledge, the 2006 and 2007 systems are identical hardware. But the 2007 RC came with v13 of the master code installed, which has specific support for the new radios. If you haven't yet updated the master code in your 2006 RC, that might be an issue.
(To check the master code version, press the mode button on the OI until it shows the 3-digit user value. The display will show the version number briefly before changing to the user byte value. You want to see u013 appear.)
Unread 23-01-2007, 08:52
AKA: Maynard Curtis
We're still seeing this problem. After talking to IFI, we tried the following.
1) replaced both modem cables
2) tried using other channels
3) moved the rc modem away from power sources
4) switched to the 2007 OI (shouldn't make a difference)
5) loaded default code from IFI
6) disconnected the power on OI to test 1/2 sec timeout (passed)
Still seeing intermittent modem losses. We did discover the RC is losing the link first. Sometimes it recovers before the OI realizes there is a problem (never see a modem light on OI).
waialua359,
I suggest you contact IFI. It could be an unrelated issue, but it sounds very similar.
I'll call IFI again when the sun gets a little further west.
Maynard
Does Anyone Have a Liability Form? Beth Sweet General Forum 5 21-12-2004 22:58
Does anyone Have? Chris Championship Event 0 24-04-2003 18:46
Does Anyone have advice archiver 2001 2 23-06-2002 23:50
Does anyone have... archiver 1999 2 23-06-2002 22:59
Does anyone have a picture of the Pratt and Whitney engine that was at Nats.? Elgin Clock Championship Event 4 08-05-2002 21:31
