Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
  #46   Spotlight this post!
Unread 23-01-2007, 09:15
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Custom Chargers for backup battery
Originally Posted by dcbrown View Post
Many regulator circuits worry about sudden current discharges and transient spikes delivered back into the output pin of the regulator and put a protection diode across the input/output pins. D1 in essense is across the pins but in the reverse direction of what is needed so the regulator isn't protected. I guess if you burn out the chip you might not notice because you still have R1 delivering 100ma+ charging current?
For me, D1 is the real fly in the ointment. It's hard for me to tell what it is doing to the current coming directly from the 12V battery.
If the regulator voltage is at 8.3V and the battery is below this, then I guess D1 is reverse biased, and has no effect. The only way D1 comes into play is if you disconnect the backup battery.... If this happens it shunts the 12V to the regulator output... which is innecessary since the D2 would shunt it to ground anyway.
IMHO D1 would be much better served protecting the backup battery from being discharged when the 12V breaker is off.
Phil.
Phil Malone
http://www.GEARSinc.org
  #47   Spotlight this post!
Unread 25-01-2007, 17:36
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Modified schematic now posted on IFI: http://www.ifirobotics.com/docs/firs...up-charger.pdf
I've posted a layout at: http://www.chiefdelphi.com/forums/sh...ad.php?t=52541
  #48   Spotlight this post!
Unread 26-01-2007, 11:14
Raym Raym is offline
FRC #1138
Raym is on a distinguished road
This circuit is improved!
But I feel there should be a current steering diode in the path from the 12v main battery to the backup battery. Without that, when the main is shut off, there is still current leakage back to all of the 12v circuitry.
Ray M.
Team 1138
  #49   Spotlight this post!
Unread 26-01-2007, 15:29
PhilBot's Avatar
AKA: Phil Malone
Your link didn't come out... Here it is in full.
Yeah, the addition of that connector makes a HUGE difference!!!!
And now that I've seen this schematic... it looks familar, as if I've seen it before. Maybe we've all been pointing at an old schematic.
Phil.
Phil Malone
  #50   Spotlight this post!
Unread 27-01-2007, 10:44
I agree that an additional diode would help this circuit and prevent back feeding the rest of the robot.
The diode in the schematic is a Schottky diode with a 0.4 volt drop instead of the 0.6 volt drop of normal diodes.
What we all need to realize is the 317 regulator will provide all the power needed by the 7.2 volt buss (at 8.5 volts) until the main battery falls to about 9.5 voltsor less. When this occurs, the output of the regulator will fall and when the output is less than about 7 volts, the backup battery will begin to supply current to the backup buss at 0.4 volts less the terminal voltage of the 7.2 volt battery. The resistor in parallel with the diode will also pass some current in each direction. The effect is that servos will not be running on 6.8 volts or less so teams should not be surprised if there servo operated devices run slower at lower main battery voltage.
There is still no substitute for a fully chargd backup battery working alone.
  #51   Spotlight this post!
Unread 08-02-2007, 12:22
Chuck Merja Chuck Merja is offline
Chuck Merja is an unknown quantity at this point
Smile Re: Custom Chargers for backup battery
So this might belong in a discussion of off robot charging, but I'll put here too. Last year we used VEX bats and VEX intelligent charger for our backup bat on FRC robot. Looks like we can still use the bats, but maybe not the charger, which seems far superior in regard to life expectancy of backup batteries.
If we are really forced to use the supplied wall wart to charge our backup bat, we probably won't risk ruining a VEX bat in the process. Seems like a step backwards - and I'm pretty sure DLavery wouldn't use the wall wart on his second car - (on Mars).
  #52   Spotlight this post!
Unread 08-02-2007, 12:30
FRC #1138
Now that we have actually built this circuit, and placed it on our machine, I am more convinced that it needs an input current steering diode.
When the main power breaker is turned off, the RC, Victors ,and such stay alive. Within a few seconds, the RC starts to indicate low voltage, but keeps on going.
Is this really what IFI had in mind?
Ray
Team 1138 Eagle Engineering
  #53   Spotlight this post!
Unread 08-02-2007, 14:26
Ray, connect it through a spike. Power the robot off, the spike disconnects.
Can you put an ammeter on the backup battery and measure the charge rate? I get about 100mA even with a fully charged backup battery. If we use the charger, I will probably use a timer to turn the spike on and off to prevent overcharging.
Even without the charger, our RC will stay energized after the main breaker is turned off, until you hit the reset button.
  #54   Spotlight this post!
Unread 12-02-2007, 17:47
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
We built a couple (one for a spare) and measured ~98ma charge current with a fully charged backup battery (~7.4v). Disconnecting the 12v and the RC we measured a ~5-6ma discharge current back through the charger circuit. We haven't pulled the 43ohm resistor, but the next one we build we leave out this resistor to measure how much charge is coming through the regulator and how much is unregulated through the 43ohm resistor.
Bud
  #55   Spotlight this post!
Unread 13-02-2007, 08:20
That is a design feature. The IFI manual says it will shutdown in about four minutes if you forget.
  #56   Spotlight this post!
Unread 13-02-2007, 10:07
The manual describes the behavior with the 2004 master code. In 2005, the timeout changed to something more like ten seconds.
  #57   Spotlight this post!
Unread 13-02-2007, 10:51
This from the RC reference guide 6/13/06
The Robot Controller cannot start running from Battery Backup power only. It requires Main Power connected at the required voltage to initially power on. If Main is lost and a link with an OI connected to an Arena Controller had been established, the RC will continue to operate with only Battery Backup power for approximately 4 minutes before it automatically turns itself off. If Main Power is lost under any other condition, the RC will continue to operate with only Battery Backup power for approximately 4 seconds or until the RESET button is pressed. This is to ensure maximum Backup Battery life.
  #58   Spotlight this post!
Unread 13-02-2007, 15:31
natis's Avatar
natis natis is offline
natalia
AKA: natalia soberanes
FRC #0987 (High Rollers)
natis has a spectacular aura aboutnatis has a spectacular aura aboutnatis has a spectacular aura about
Send a message via MSN to natis
Hey, One question is anyone making the backup battery custom charger for sale??
just wondering!
natalia
Team 987 - The High Rollers - Las Vegas, Nevada
2002 -- Nationals Highest Rookie Seed
2003 -Xerox Creativity Award
2004 -LA Regional Semi-Finalists
2005 - Arizona Regional Finalists -- GM Industrial Design Award -- Las Vegas Regional Champions
2006 - Delphi "Driving Tommorow's Technology" Award -- Radio Shack Innovation in Control Award
2006 - Las Vegas Regional Champions -- Arizona Regional Finalists
2007 -Motorolar Quality Award
2007 - SVR semifinalist -- Las Vegas Regional Finalist
2007 --WORLD CHAMPS!!!
  #59   Spotlight this post!
Unread 14-02-2007, 15:13
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
just wondering!
natalia
Actually, if you're attending the San Deigo or LA Reagonal our team, 1388 will be handing out the boards and materals for them (some assembly required) and you can make them for your bot.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Automatic battery chargers only? sanddrag Electrical 1 12-01-2005 23:38
[OCCRA]: different battery chargers? no chance OCCRA Q&A 1 28-10-2004 05:34
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
