Go to Post When you do something great, it just feels good. - tiffany34990 [more]
Unread 22-01-2007, 22:18
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
Whats the Robot Signal light for?
What does it do? The red/black from PWM pull in the relay. Does the PWM just sit at 127 and turn on the light? WE tried it and the light didn't go on. I'm not sure the relay pulled in. It looks like there's red indicator light on the relay, but it never lit. Any help or ideas? I didn' see anything in the rules about it.
Unread 22-01-2007, 22:21
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Whats the Robot Signal light for?
The light is what they call the "Safety Light" and is supposed to function as a signal light, warning flasher, and robot status indicator light. At least this is what it FIRST says in their papers. As for actual practicality, I haven't looked into that yet.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 22-01-2007, 22:22
DonRotolo's Avatar
Back to humble
FRC #0832
<R16> ROBOTS must use the diagnostic signal LED provided in the Kit Of Parts. Field personnel
will use the LED during the matches for diagnostic purposes. It must be mounted on the
ROBOT such that it is easily visible while standing three feet in front of the ROBOT in its’
STARTING CONFIGURATION. Instructions for connecting the LED are provided on the
FIRST website at www.usfirst.org/frc/2007/manual The Robot Controller directly powers
and controls the LED. The user has no control over the LED and no programming is
required.
Don
Unread 22-01-2007, 22:54
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
The way I have interpreted the signal LED is that it is in some ways a replacement for the diagnostics side of the old LEDs.
The color aspect of the old LED has been completely overtaken by the flags and the diagnostic aspect is going to be taken by this new LED.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 23-01-2007, 10:52
Did you plug it into the Team Color outputs (black on black with one pin left unused) or a PWM output?
Unread 23-01-2007, 12:23
tvrobotics tvrobotics is offline
AKA: Andrew
FRC #1357
Team Role: Electrical
tvrobotics is an unknown quantity at this point
We have the signal light all wired up, but I dont know where it plugs in. Is there any programming needed?
Unread 23-01-2007, 12:32
AKA: Andrew
FRC #1357
Perhaps since it's a relay, it plugs into "relay" where a spike relay would normally go?
Unread 23-01-2007, 12:33
No programming is required at all.
It plugs into the same outputs as last year's LED. Any one of the four "Team Light" outputs can be used.
The new LED is wired to only use the first 3-pins of the 5-pin outputs, starting with Black-on-Black. Leaving an extra two pins exposed and unused.
It's spelled out in the last two sentences on page 38 of the "FIRST 2007 Guidelines, Tips, & Good Practices" document found at http://www2.usfirst.org/2007comp/oth...tices_RevA.pdf
Unread 23-01-2007, 17:47
FRC #1277
Ah, now I see in the Tips amd pratices. We plugged it into a pWM, not the team colors. I won't be trying it tonight, but what does it do? Does it do something under controlof the judges?
Unread 23-01-2007, 19:29
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
The signal lights are used by the IFI staff to determine what is going on with your control system if there is a failure on the field. It helps them determine if there are programming issues, battery issues, etc while the match is running. YOU WANT THIS LIGHT FUNCTIONING. I helped with the IFI field controls last year in toronto, and in addition to their radio diagnostic tools, this light is immensely helpful in quickly determining if there is a field issue (99% of the time its actually not the field!!).
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 19-02-2007, 22:51
sephiroth1021's Avatar
sephiroth1021 sephiroth1021 is offline
Matt I
FRC #2047 (Team Challenger)
sephiroth1021 is an unknown quantity at this point
What are the patterns on the light supposed to be as the bot goes from enabled to disabled?
(Sorry if this is a silly question. Rookie team.)
-Matt
Unread 20-02-2007, 06:35
This is from memory, so don't take it as authoritative. If you're tethered, I think it blinks no matter what. If you're connected by radio on channel 40, it blinks when enabled and is on steady when disabled. If you're on channel 31, it stays off.
A team color LED assembly from last year tells more of the story. Different channels blink either red or blue; tethering alternates both. This year's amber signal light comes on when the old light would be red.
Unread 20-02-2007, 08:29
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Thats correct. The only thing that disappoints me about this new light is that the Autonomous and Human Operated modes both have the same flash pattern, as opposed to the previous hyper-flash for Autonomous and the slower flash for Human Operated.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
How to hook up a Police light on the Robot?? xur2007 Technical Discussion 4 13-11-2006 18:27
PIC Signal to Robot Controller Pin Map Kevin Watson Programming 2 20-01-2006 18:32
Another team's robot signal not working zeep25 Control System 2 25-02-2004 23:33
Whats the delay for??? archiver 1999 4 23-06-2002 22:49
The light for the robot Mike Norton Technical Discussion 4 12-02-2002 15:23
