Go to Post I am definitely not a battery or battery charging expert (far from it) but I do know enough to be dangerous (I stayed in a Holiday Inn Express last night)... - Don Wright [more]
Unread 23-01-2007, 00:36
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
default drive?
Hi all!
Today we got 50% of the robot running!!! (the right side)
I'd like to know what pwm pins and such are used by the "default" program in there. I think I have pwm output to a victor hooked up to my right cim motor. Now I have pwm output to the other victor hooked up to my left cim motor... but either that does not work (hope not)... or the default isn't Port 1 & 2 on the operator interface!
Does anyone know?!?!
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 23-01-2007, 01:48
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Re: default drive?
The default drive code uses pwm 13 - 16. pwm 13 and 14 are side of the robot and 15 and 16 are the other side. Here's the code if your interested.
pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 23-01-2007, 06:52
Re: default drive?
Read the default program. You can find it at http://www.ifirobotics.com/rc.shtml (it's the 2007 RC Code link) if you don't already have a copy. It is well commented. The relevant part is Default_Routine() in the user_routines.c file.
Unread 23-01-2007, 13:23
GMKlenklen's Avatar
The "Masonater"
Re: default drive?
so uh... how do I open .hex files? to look at them / edit them?
Thank you,
-of the MASMabots-
Unread 23-01-2007, 13:27
dpick1055's Avatar
David Pick
Re: default drive?
You don't want to open the .hex files. You download default code (the link was posted above, I don't remember it off the top of my head). This will come with a bunch of .c and .h files and an MPLAP workspace file. Once you install MPLAB which came in the kop you can open these files and edit them. You should read the programming getting started thread it has a good explaintion of all of this. http://www.chiefdelphi.com/forums/sh...ad.php?t=30976
Good Luck!
Unread 23-01-2007, 15:32
GMKlenklen's Avatar
The "Masonater"
Re: default drive?
sweet, thanks
Thank you,
-of the MASMabots-
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Default Code Idaman323 Programming 5 12-02-2006 17:14
default program nick_champ_2 Programming 2 06-02-2003 13:11
default code archiver 2001 2 23-06-2002 22:53
